Problems..
Problems..
I was changing my xml, didn't exactly do it right so I decided to reuse the original. When I opened Ecuflash and tried to open a rom I got alot of trouble from the program. This is what it says..
Unknown ROM Image
This wizard will generate the basic ROM definition information needed to start working with this ROM image.
O Defined from scratched
O Copied from the definition below
O Inherited from the definition below
then it gives you something to select 'something' from, which nothing shows up.
Also I had 1.29 and I think I might just upgrade now.
I tried messing around with some of the options and Ecuflash keeps just unexpectedly quitting. I'm trying to reinstall it and what not.. any tips?
Unknown ROM Image
I downloaded 1.33 now and now I'm getting...
Unknown ROM Image
Ecuflash could not recognize this ROM image using any of the current definitions. You can choose one of the following options:
O Abort using this ROM image (with no chance of saving)
O Continue using this ROM image with no definition (no editing or viewing, but saveable)
O Use wizard to create a new definition ( NOT RECOMMENDED!!! - FOR DEVELOPERS ONLY)
Cancel <Back Next> Finish
Unknown ROM Image
With 1.29 it was probably an extra </table> tag in the xml or something similar causing a script error. It will also shoot an error message like script error at line 338 column 8 or something like that.
Doublecheck the xml and see if its still available. I personally refuse to use anything above 1.30 and if I hadnt accidentally corrupted 1.29 I woudlnt have stopped using that.
