Let's see your fully tuned timing maps
#1533
all my logs are on my other computer ill try and dig something up, but it was taking more timing with no knock at that point. not quite sure how a cat would lean me out...although i could see it raising backpressure/egt's...
#1534
the idc's are fine, but i will definitely not push them higher. ecu flash is off by a minimum of like 5%.
#1540
You're probably leaner than you think. Putting an exhaust or test pipe will make you run leaner. This is a log of mine with a similar knock pattern:
You can see the combination of aggressive timing and lean-ish condition can give you knock. Not sure what gas you're using too.
#1541
its 93 octane, and the timing is not very aggressive. afr's were tuned to about 11.5 if i recall.
#1542
im sorry, but i still dont see how putting a cat on the car will effect mixture, i may be wrong, so if someone could explain the theory...because its totally not making sense in my head.
#1544
Regardless of the cause your knock seems to need a rework of the tune. So might as well just do it. Or wait to put on your wideband and do it.
#1545
In regards to the low octane maps I can agree with killerpenguin that its a nice safety feature but only against bad gas. As for when your tuning I set them to the same as my high octane maps to keep it consistent. When the tune is finished I adjust the low octane maps to add back in the safety feature. I only run a few degrees of timing difference.
