Let's see your fully tuned timing maps
Old Dec 8, 2007, 12:27 PM
  #181
homiusang's Avatar
Originally Posted by bigric09
ah, im still using 1.29a, because non of the other versions ever want to work for me
same here, seemed only the older version can only work on my multiple computers at home
Old Dec 8, 2007, 12:36 PM
  #182
4WS Tuning's Avatar
you dont need the graphing stuff..... 1.29 is reliable and works well..
if you want flashy stuff i reccomend
www.spankwire.com
Cheers!
Old Dec 8, 2007, 01:25 PM
  #183
GTLocke13's Avatar
Dude... NSFW. I expect that in the OT forums, not here.
Old Dec 8, 2007, 02:03 PM
  #184
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
classy
Old Dec 8, 2007, 06:41 PM
  #185
TouringBubble's Avatar
Originally Posted by nothere
3d map charts, you can rotate them to mimic the 2d graph, still a little awkward to find a cell but it can be done.
ecuflash vrs 1.33, or better
you have to click the view to select.
The 3d graph has been in ECUFlash for a while .. 1.29 at least ...
From a 3d map, select View > View Graph (Alt + G)
Old Dec 9, 2007, 07:35 AM
  #186
bigric09's Avatar
hmm. interesting, i will check that out... thanks man
Old Dec 9, 2007, 01:43 PM
  #187
Spoolin.'s Avatar
My 93octane map tuned for 22psi and with some cool weather I have been able to spike as high 25psi with no knock.
Old Dec 9, 2007, 03:36 PM
  #188
esevo's Avatar
Originally Posted by Owens Racing
appears he is in ecuflash. I am interested too.
I am using ecuflash 1.30... The 3d graphing helps when blending
Old Dec 9, 2007, 06:54 PM
  #189
PlanoEvo's Avatar
www.spankwire.com
Cheers!
4WS FTW!!! Nice Way to buck authority! Nice holiday spirit...
Old Dec 9, 2007, 08:32 PM
  #190
mplspilot's Avatar
www.spankwire.com
Cheers!
Wow, that wasn't ghey at all...
Old Dec 10, 2007, 01:36 PM
  #191
Slo_crx1's Avatar
Here's the one I'm currently working on...'03 VIII, TBE, cat delete, Injen intake/uicp/licp, TurboXS Type H-34 valve, 10.5 hotside, 93oct. @ 21psi tapering to 19psi controlled through EcuFlash...
It's a work in progress, and I have to extend the load portion out one more block if possible, have been getting very close to the edge of that 260% load section. Still getting 2 counts of knock when I shift and 3 counts during part throttle, but it may be due to the recirc valve (wouldn't do it with the stock plastic piece, but the nipple broke off so for now this valve has to do). Let me know what you guys think, it pulls like an animal but compared to everyone elses timing maps I seem to have quite a bit more timing.
Old Dec 10, 2007, 01:44 PM
  #192
RazorLab's Avatar
holy timing. 9* at peak trq?
Is this with meth?
Old Dec 10, 2007, 01:50 PM
  #193
Slo_crx1's Avatar
Is this with meth?
Nope. Just straight 93 octane pump. Never had any knocking issues at peak torque, and the most knock count I get is usually less than 3 counts down below (which I'm still working on...would be nice if I could get my other laptop with LogWorks to connect to my lc-1 ).
Old Dec 10, 2007, 01:52 PM
  #194
bigric09's Avatar
his is an VIII for one, and he doesnt have cams listed. My IX pre cam map is not too dissimilar from that map... maybe a degree or so off here or there
Old Dec 10, 2007, 01:55 PM
  #195
Slo_crx1's Avatar
Sorry, I didn't list cam specs because they're still stock for now. I have a set of BC 272's to put in, but I'm waiting until spring for that, that way I can retune during warmer temps and hopefully not have any issues. Just an FYI, the average temp where I live has been in the low 30's for the past 2 months while I've been working on this, so it may have a good part in why it's so high.
Quick Reply: Let's see your fully tuned timing maps
