Let's see your fully tuned timing maps
Old Apr 27, 2014, 06:37 AM
  #2536
brusinn's Avatar
Originally Posted by mavraolan
How does this look like? I will try it next weekend so any suggestions are welcome. I will use this combining with JDM RS MIVEC map.
how do u guys post the larger pictures from ecuflash?
its tephramod v7 bigmaps
Old May 8, 2014, 10:03 PM
  #2537
LightningTuned's Avatar
I came from tuning Black Box DSM's and finally got an Evo. I have phantom knock in the low rpm/low load (2600-3500) that i need to dial out, but I'm relatively happy with this tune. I have tried pulling timing, as much as 3* in that area but still have the knock, I'm going to investigate my downpipe now. Stock 8 turbo 21 psi, LICP, BC 272's. I think i can get away with ramping up the timing a bit around 160+, but i want to be relatively conservative. Let me know what you think
EDIT: Here is a log from this morning (my wb02 currently is no set up for logging
http://www.filedropper.com/evoscandatalog20140509062546
Old May 9, 2014, 07:50 AM
  #2538
aggieEVO's Avatar
I wonder if the knock could be from inerpolating your fuel map. Seems like you have some big jumps. But, I'm new to tuning and could be wrong. Maybe when you can properly log your WBO2 you'll be able to smooth it out a bit more.
Good luck.
Old May 9, 2014, 01:36 PM
  #2539
todd6027's Avatar
pointless exercise without a wideband , log only whats needed to tune it like rpm /tps/timing /2 byte load /knock /inj duty
Old May 9, 2014, 07:18 PM
  #2540
Abacus's Avatar
Nice looking timing map. I'd take a little timing out around 2000-2500. Thats alot of lead for a low engine speed/load. You could have some tip in rattle
I run about 19-25 in that area ramping up after that to 37.
Old May 25, 2014, 01:26 PM
  #2541
superbovine's Avatar
Heres about where I am now. Still feels sluggish though, not sure where to go from here. I get occasional single count knocks at low end and feel like it is pretty lean already.
Running typical mods, IX turbo, 3", intercooler and lower piping, PTEs, COP etc.
Attached Thumbnails Let's see your fully tuned timing maps-capture.jpg   Let's see your fully tuned timing maps-capture2.jpg
Old May 25, 2014, 03:05 PM
  #2542
Benja's Avatar
Pull a degree of timing from 130-210 load areas in the 2750-3500 zone, smoothen out the transition of timing in surrounding areas.
Your AFR at 10psi is fine, richen up the AFR and aim to be hitting 11.5 by 3.5k and ramp it down smoothly from 10psi/12.1 to peak boost 21psi/11.5. That will make it come on a little harder and punchier than leaning it out.
I would add a degree at 4500 to 6, another at 5000 to 7 and try to have a smooth ramp up in timing.
Old May 25, 2014, 03:46 PM
  #2543
Thanks, I'll give that a shot. I've scaled my injectors one tick up since that log as I am ***** footing around the trims trying to get it dead nuts on (PTE1200s, they are a bit finicky it seems). So the AFR is going to be a small margin leaner already. I'll take another log later on and see where we are at with another 3rd gear pull.
Edit: Yeah it didn't like that much. Power fell flat entirely, really odd feeling. I've driven Corollas that felt better. Not sure how that happened. Got a good amount of knock at mid load somehow too.
I didn't bother to take a log (wasn't planning on driving at that moment but had to go do something), I've just reverted to previous for right now until I can dig into it some more.
Old Jun 20, 2014, 11:50 PM
  #2544
Jwhalen07's Avatar
S362FMW, very responsive from cruise to WOT. Knock sensitivity adjusted in areas. Makes 28psi around 4k rpm in 4th gear on E85. Just need to fix the from idle to cruise area to make it more responsive so I don't have to slip the clutch so much to get rolling.
Old Aug 4, 2014, 08:20 PM
  #2545
TBCT9A's Avatar
I just started tuning the Evo. I wanted to improve and correct the factory map, to use it as a baseline before installing bolt-ons, and a boost controller. This is a bone stock 9 on 91oct. , i believe peak load is 230 by 3300rpm , and tapers to around 190 by 7000rpm. Can you guys critique what i have so far?
Old Aug 4, 2014, 08:33 PM
  #2546
Raptord's Avatar
Have you checked it with the graph? That will also give you a good idea of places where you might have missed sharp transitions, etc.
At first glance though, it looks decent. Might try smoothing out that 120 to 140 load transition a bit as it's pretty steep as it is now.
Old Aug 9, 2014, 05:15 PM
  #2547
TBCT9A's Avatar
yea, ive logged it a bunch of times. I'm trying to be conservative on the timing since its on 91oct. Waiting to throw it on the dyno soon.
thanks for the suggestion on the steep transition. I tried making it smoother. here it is
also gave it a bit more fuel up top because it had a few knock counts at 6000rpm+
Old Sep 18, 2014, 12:37 PM
  #2548
420a-t's Avatar
What are most of you guys seeing for timing on built motors pushing 35/40+psi on e85? Looking mainly what the end of the rpm range looks like as well as at max torque.
Thanks for any info
Old Sep 26, 2014, 04:44 PM
  #2549
kpr
kpr's Avatar
I keep seeing timing map with 15-20 at 0-1000rpm. Most of these are E85. Is that normal for E85, and if so why?
Thanks
Old Sep 26, 2014, 04:56 PM
  #2550
domyz's Avatar
Thanks
More vacuum= Stable idle with cams
Quick Reply: Let's see your fully tuned timing maps
