Let's see your fully tuned timing maps
Old May 15, 2017, 02:45 AM
  #2686
darwin_evo's Avatar
bump
Old May 15, 2017, 02:02 PM
  #2687
darwin_evo's Avatar
so we tuned the car on the dyno, on e100, but it seemed to stop making power at the following timing/rpm:
6500rpm 12*
7000rpm 13*
7500rpm 14*
8000rpm 15*
8500rpm 15*
boost: 42psi
turbo fp super 94
engine 2.2L
I don't trust the dyno as it's not properly ventilated. Timing seems a bit low to have reached MBT
any opinions?
Old May 16, 2017, 06:39 AM
  #2688
detroit pistins's Avatar
^ Are you on a stock ecu or aftermarket?
Old May 16, 2017, 07:57 AM
  #2689
2winscroll's Avatar
6500rpm 12*
7000rpm 13*
7500rpm 14*
8000rpm 15*
8500rpm 15*
boost: 42psi
turbo fp super 94
engine 2.2L
any opinions?
When it stops making power your at MBT. Make sure your base timing is correct, many times it's not. Another is flat top pistons give more quench area which speeds up the burn. E100 burns slightly faster than E85 also.
Old May 16, 2017, 09:05 AM
  #2690
darwin_evo's Avatar
Thank you for the inputs.
We are on stock ECU.
The thing is I'm not sure about the dyno consistency, that's why i'm looking for input from people with similar setups or that have experience with tuning at such boost/power levels
Tks
Old May 16, 2017, 12:55 PM
  #2691
butte's Avatar
Just curious, what's meant by 'base' timing as opposed to the timing he's seeing in his logs?
Old May 16, 2017, 01:56 PM
  #2692
ronaldo9's Avatar
If the cam timing is off it will show some funky ignition timing values in the log.
Old May 16, 2017, 03:43 PM
  #2693
darwin_evo's Avatar
any more opinions guys?
Old May 16, 2017, 05:44 PM
  #2694
2winscroll's Avatar
Things that will throw off your base timing; cut cylinder head, different head gasket thickness, some aftermarket cams, changing your exhaust cam timing. It's usually never perfect. Doesn't seem to far off, why were you expecting to get more timing out of it? If your worried about the repeatability of the dyno, do several pulls but let the engine cool down in between pulls. Not necessarily funky just may seem low or high from the norm.
Old May 17, 2017, 10:47 AM
  #2695
Sounds like someone did thier combustion hw
Old Jun 15, 2017, 08:54 PM
  #2696
EvilDSM97's Avatar
A friend gave me this map to use as a starting point from another car he tuned with similar setup. I have not done too much of anything to it yet. I am seeing 8* peak at 7000rpm.
Evo 8 with Borg warner s363, HKS 280's, stock bottom end. 31 psi (Thinking about turning it down to 29-30)
No knock at all.
VD DJ numbers are 498/390.
If anyone spots something I should change in the map and can point me in the right direction that would be helpful.
Old Jun 16, 2017, 08:34 PM
  #2697
matt1937's Avatar
No knock at all.
VD numbers are 498/390.
what fuel?
Old Jun 16, 2017, 08:50 PM
  #2698
EvilDSM97's Avatar
Originally Posted by matt1937
what fuel?
This is on 93 pump
Old Jun 19, 2017, 06:45 AM
  #2699
mrfred's Avatar
This is on 93 pump
Depends somewhat on AFR as well, but for 500 whp, 8 deg seems about right. Are you at 31 psi at 7000 rpm?
Old Jun 19, 2017, 08:27 AM
  #2700
EvilDSM97's Avatar
Thanks for replying, I was hoping someone as knowledgeable as you would be able to give me some input!
I've since turned the boost down slightly, right now it is around 30.5psi at 7000. Previously it was around 31.7-31.8 at that same rpm. I know that is Not much of a difference but it does make me feel just a little safer. 😄 My VD numbers are 490whp now, I was hoping I could make up for that in adding a little more timing up top, however I cannot seem to get timing above 9 degrees, regardless of what I try to add. Not that it knocks, it just will not advance anymore at all. Looking closer at my timing map the car seems like it is taking the path of the 340-350 load timing column but I have not verified that yet. Evoscan is showing me 315-320 peak load.
I have a thread in the Evo tuning dyno results section if you care to take a look so that I don't clutter this thread.
Quick Reply: Let's see your fully tuned timing maps
