Let's see your fully tuned timing maps
#1193
I have my knock multipliers adjusted slightly, but more so on the low-end, only a slight adjustment during mid range, and stock setting on top end. I'm not sure exactly what RPM ranges each table reflects. I did this when I changed my front motor mount. Literally, that same day, my logs started showing more knock counts than ever. But, that was pre-cams. I also followed Merlin's way of determing false or phantom knock from real knock.
#1195
You can cheat and open your map in ECUFLash - or appropriate software - and highlight a selection of cells and interpolate horizontally, vertically, or 2-dimensionally. If done correctly there will be a gradual transition applied from cell x(1) to cell x(n), with the difference between adjoining cells approximately [x(n)-x(1)]/(n).
Hopefully this made sense, and if I went overboard I blame sleep deprivation.
#1196
interpolation via shortcuts in ECU flash is a way to achieve numbers that make sense, but it should not be used as a way to achieve the correct numbers, it will put a straight line in portions of your mapping that maybe should have a little sag or hump. A great example of this is if you ECU Flash shortcut your (7000rpm,20load) all the way to the (7000,300) you would end up with some unfavorable conditions. So in summary, for short spans ECU flash shortcuts may work, but I would be a bad choice to do large quantities of map with this method.
Fuel mapping wont be as uniform and have logical numbers. Most of the time theres a crossover point. where AFRA= AFRM and on either side of it its off by a lot.
#1197
I would say 13 degrees up top on a stock turbo is being conservative for an VIII. I run 17 degrees up top and barely ever got knock as long as my AFR's are in check. After 17 degrees, Knock counts were sporadic, but more often than I like.
Below is my map. 352whp and 346 ftlbs on VD. 25.5 psi tapering to 20. All boltons, no cat, 264/272 cams.
Yes, I enjoy the sounds my car makes when I shift.
a
a
#1198
So Wizzo got me thinking... I'm not sure how much value there would be in a "Fully Tuned Fuel Map" thread but what about a "Fully Tuned Boost(WGDC) Map" thread? Might be interesting to see, especially for those that are on gear-based boost. Just thought I'd ask here before actually starting the thread.
