Boost Enhancement Table Addresses?
Old Jan 30, 2008, 06:19 PM
chmodlf's Avatar
Does anyone know the addresses for the following 94170008 ROM tables?
Thanks
<table name="Boost Enhancement Enrich/Enlean (Anti-lag) Map" category="Fuel" type="3D" level="1" swapxy="true" scaling="AFR">
<table name="Load" type="X Axis" elements="19" scaling="Load"/>
<table name="RPM" type="Y Axis" elements="20" scaling="RPM"/>
</table>
<table name="Boost Enhancement Adv/Ret Map 1 (Anti-lag)" category="Timing" type="3D" level="1" swapxy="true" scaling="Timing">
</table>
<table name="Boost Enhancement Adv/Ret Map 2 (Anti-lag)" category="Timing" type="3D" level="1" swapxy="true" scaling="Timing">
</table>
Old Jan 30, 2008, 10:15 PM
Jorge T's Avatar
Thanks
</table>
3ff5
</table>
3ce5
</table>
3e6d
If these tables are active in our ECU(which I belive they are, 3e6d looks like the "vacuum advance" cruise mode map) then when we rescale the map the values get shifted. I believe is what was causing partial throttle knock. Once I carved out the ovelapping zones I got rid of it.
What I don't get is why the enrich/enlean map uses a timing map format for AFR.
Old Jan 31, 2008, 02:29 AM
burgers22's Avatar
From the disassembly I have done, I think this map is incorrectly identified as an AFR adjustment, it is a table referred to in the ignition sub routine, so it makes sense that it has the ignition Load and RPM axis.
MB
Old Jan 31, 2008, 07:41 AM
Jorge T's Avatar
Ive looked at the 3d values in hex8, uint8, load8, & AirFlow8 but they mean nothing to me...idk.
Old Jan 31, 2008, 11:25 AM
chmodlf's Avatar
Edit. Mispost
Old Jan 31, 2008, 04:06 PM
chmodlf's Avatar
Jorge T or anyone.
Do you have the x and y addresses for the above?
Thanks!
Old Jan 31, 2008, 04:22 PM
Jorge T's Avatar
use the same addresses found in the timing maps
Old Jan 31, 2008, 05:50 PM
chmodlf's Avatar
Thanks.
tephra
Mar 31, 2024 01:17 PM
Boosted Tuning
Aug 26, 2023 10:14 PM
tephra
151
Jun 18, 2017 03:22 PM
tephra
May 16, 2016 09:24 PM
AIK
10
Sep 13, 2010 02:48 PM
Quick Reply: Boost Enhancement Table Addresses?
