Official 2 byte thread!
#361
Hey, I'm in the same boat as Rpf1evolution. Same rom 96940011, all the data is there. I have evoscan 2.9 with Mut2byte airflow and load preset. Both are gathering info from the corresponding 00 01 and 04 05 MUT addresses which is already visible to me. I cannot get a usable number from 2byte load. The equations are correct as well. It does say in the description that I need a tephra modded rom. Should I try switching Rom I'ds and take a second go at it?
MAKE SURE your addresses are correct for YOUR rom and also double check your evo7base.xml in ecuflash with notepadd++ or something like that. you could have copied or typed something by accident or commeted something out. check the simple stuff before you go reflashing.
only reason i say this is because for my rom id the MUT address was listed wrong on ecuwiki but the address in this thread WAY back at the beginning is actually the right 1. I went with the wiki thinking it would have been updated more since the original posts but it had conflicting mut table addresses. after changing the mut address and a reflash everything came to life for me.
good luck!
