PATCH: TephraMod V5
#917
anyways so the links to the ROM 90550001 will be on the first page of post correct????? just tried it and still no go....
#918
Tephra or somebody who can help me:
I just finished installing my Alt-Map switching on my Evo IX and HFS-1 system. However, my NLTS isn't working. When I turn the aquamist gauge off/on the little led light comes on indicating which map I'm using. The only problem I could think might be causing this is not installing the ECU pin correctly. I wasn't able to locate a complete set of instructions. I just pushed the pin through the back of the wire connector; not sure if this is correct though. Can you give me advice on how to troubleshoot the problem? In ECUFLASH I have the NLTS set to 1 which I'm guessing means 'On'. If the LED light indicator works does that mean the ECU pin is installed correctly?
#919
yeah the aussie uniform sucked big ****....
cheap and nasty hey
new thread up:
https://www.evolutionm.net/forums/sh....php?p=5989664
cheap and nasty hey
new thread up:
#920
#921
cheap and nasty hey
new thread up:
cheap and nasty hey
new thread up:
#922
I finally had the pleasure of using NLTS for the first time on a good transmission/clutch tonight.
Freaking awesome! I'm set at 300RPM right now and it's almost perfect for me. 250-275 should be perfect I think.
#923
EvoM Community Team
The LED on the alt map harness will come on when the "PIN" has 4.7 volts going to it, doesn't mean the ECU is switching maps correctly though. The best way to confirm that the maps are indeed switching is to datalog it. I believe its MUT address 41 or something (its listed in this thread about a 1000 times,lol). 0 means alt maps are off, 3 means they are on. I noticed if you go below the 1500ms 'Alt Map Time to Activate' setting, it won't actually switch maps for some reason.
(it shows 4 when switched on after the pause and 0 when switch off. Volts value shows 4.98046875 continuously)
Can somebody tell me what I'm doing wrong so I can fix my junk and the wiki? I can see it pause for the 1.5s and then see the idle timing change etc.
#924
I haven't looked too far into it yet but I noticed the eval for the "Alt Map Input voltage" should be (x/255)*5, not 256. Also, they are both response bytes of 1, not 2.
Seems like something internally in the ECU might be shutting off the Alt-Maps. Are you using any failsafes to trigger the standard maps??
#925
EvoM Community Team
Well, the on-off action was me just pushing the switch... it was switch only so there shouldn't be anything else interfering there. I should have seen the 255 error... but that barely starts to explain that. That means the voltage it is reading is a constant 5v according to calculations. I thought that initially there was a ceiling on the value (and now see that it was just the calc) so I was thinking that I may have had the already shrink wrapped zener backwards. From this I tried going full test and it pulls that value switch on/off including when I connect/disconnect power and ground to the whole switching system. Unfortunately my multimeter found its way out of my electrical box, so I'm out of luck on that for now.
I checked the response bytes and I'm using 1 (evoscan equations)... I just grabbed the MitsuLogger equations out of this thread. I'll fix those stat.
Let me know if you get any other good ideas. I don't think I'm overvolting it, I'd just like to be sure and be able to fix the wiki.
#927
EvoM Community Team
As far as I can tell they ARE switching. I'm just logging some strange values. I flipped the switch with the car running once and have my old pump maps on my alts and only ~5 degrees timing at idle. On my main E85 map I have ~14deg of timing at idle. After the pause I see the timing drop drastically into the correct range after I flip it.
