Patch how-to: manifold air temperature logging
So because I have MAFT Pro for my speed density conversion I have the GM IAT and wiring. I am thinking that I can vampire that and run it in like you described? This is really cool...Good work MAN!!!
I have been monitoring the MIAT with the MAFT pro but havent been able to log it. It will also be cool to see what effect things like the intercooler sprayer actually have on the temps.
A shopvac with a 90 deg fitting on the end of it might actually work. Maybe a brush fitting if it fits through the opening on the manifold. Otherwise, it would be some custom thing. I'll have to give that some thought. Would be much nicer to have it taped there than on the IC pipe before the TB.
Yeah, I realized that I wasn't even thinking of what the IM was made out of. I was too quick in remembering tapping something else with that method, that I didn't take the time to stop and think first.
Chalk up a retard point for me. I might have to give back my Materials Science and Engineering degree now.
Eric
Eric
Here is an idea on tapping intake manifold. Does it work? Yes, but it is a risk. I have used this method on other cars. I am not responsible for you damaging your engine or turbo with this information. Use your boost leak detector to pressurize the intake. Put allot of grease on the drill bit. Drill hole. Most chips will stick to drill bit some will blow out. Now with air blowing everywhere tap the threads with grease on the tap too. Will still blow out chips and most will stick to the tap. After you finish with tap, it is important that you check for anything that may have fell inside the intake. You can use a long q tip with grease on it to pick up any thing you notice. Risky, but might work for you. I suggest you remove the intake though, it is much safer.
Seriously, if you suck something into the cylinder, how long will you be without your DD?
It only took me about 30 minutes to pull the IM, 30 mins to drill and tap and blow it out with brake cleaner and air, then 45 mins to put it back on. 2 hrs max, and no worry that you might have ingested something deadly.
