Detailed mapping of Periphery bits underway
#166
LOL There actually is a Periphery bit that disables the OBD-II communications, I had stumbled across the bit when I was experimenting with the settings from Euro cars to figure out how to disable some of the functions and tests. Good thing you discovered it was basically nothing
I found this information on page 4 and i thought that by mistake someone changed something and blocked data loging. I am trying to find out what is the issue with my ECU because everytime when I try to data log by any program it says unable to connect to ECU when the car is running.
#167
#168
if that doesnt work try 62500 for the baud rate in evoscan
#169
Sorry for late reply but it took me some time to check everything.
I checked the wire and it seems to be ok.
Obd pin 1 --- ECU pin 56
Obd pin 4 -- ground
Obd pin 5 -- ground
Obd pin 7 --- ECU pin 62
Obd 16 --- 12V
So everything should work. I checked if logging works when the engine is not running and it works ( it shows coolant temperature, throttle position and more) when I start my engine ecu is being disconnected.
I also checked different baud rates with no result.
ECU which I am using is RA560649R1 (evo7) with Tephra v5.01.
I also made screen shots of my pheryphery for your review.
Obd pin 4 -- ground
Obd pin 5 -- ground
Obd 16 --- 12V
senate6268
Lancer Engine Management / Tuning Forums
271
Mar 7, 2020 09:28 AM
