Logging Boost
Old May 10, 2008 | 11:28 PM
jamie_v1's Avatar
Logging Boost
Hi does anyone know how to use the avcr pressure sensor to log boost with
evoscan
Old May 11, 2008 | 06:20 AM
tephra's Avatar
does the AVCR have a 5v analogue output?
Old May 11, 2008 | 06:36 AM
dudical26's Avatar
I just looked around on the internet a bit and I read that the AVCR uses a "standard" denso map sensor with a 0-5v output. So I think it would be fine to use.
Tephra - It's nice to have some one else on the boards who is active at this time. I am studying in Sydney for the semester and I feel like the rest of the board is sleeping while I am online, lol.
Old May 11, 2008 | 06:52 AM
tephra's Avatar
lol!
u should meet up with the sydney evo guys...
evolutionoz.net for AU forums
Old May 11, 2008 | 06:56 AM
dudical26's Avatar
Thanks for the info, I think I really should do that. I am going through withdrawal not having my evo, it would probably help just to be around some, lol. I wish I had realized you live in Melbourne earlier... I was down there for the F1 race.
Old May 11, 2008 | 07:19 AM
jamie_v1's Avatar
How would i wire the map sensor up so i could use it to log the boost
Old May 11, 2008 | 11:27 AM
John F's Avatar
I've just done this on my Evo8 260. I took a feed from the AVCR harness blue wire and put it into pin 73 in the ECU. You need this formula in Evoscan 0.27882*x-21.33 to get a pressure reading in PSI. You log MUT 38. It is already set up in Evoscan, just change the formula. I see you have an Evo 6 so don't know if the situation is exactly the same for you.
Old May 11, 2008 | 03:10 PM
jamie_v1's Avatar
Thanks for that i have a evo 7 ecu fitted so i should be able to log it i am using 2 byte load and rpm do u know if this will work ok also do i enter this formula in the eval section in evoscan
Old May 11, 2008 | 03:20 PM
John F's Avatar
Looks like Evo7 and Evo 8 260 have the same ECU pin outs so I think you will be fine.
Old May 11, 2008 | 03:26 PM
jamie_v1's Avatar
Thanks again al give it a go and post up the results
Old May 12, 2008 | 09:52 PM
tephra's Avatar
nice one on the formula John!
Old May 12, 2008 | 11:45 PM
sub7's Avatar
Just curious, e7 and e8 pin 73 are not in use, do we need to mod the ROM to log the boost?
Old May 13, 2008 | 12:15 AM
tephra's Avatar
should just work
hook up a 1v source and log MUT38 without any formula.
it should read 50ish.
Old May 13, 2008 | 02:44 AM
John F's Avatar
Cheers. I knew maths would come in useful on day.
Old Oct 11, 2008 | 11:32 AM
SeanV's Avatar
This is great.....
I plan on doing this real soon on my Evo8.
What would the formula be if I wanted to log the the boost reading in Bar or Kpa?
Thx in advance
