JDM Map Sensor and Gauge
Is it possible to output the readings from the jdm map sensor to a digital gauge. I like the accuracy of the JDM map sensor and would like to get rid of my current mechanical boost gauge.
something like this
http://www.dynotunenitrous.com/store...?idproduct=131
something like this
Sounds like a good idea.
The voltage scale for the JDM MAP is available. And I agree. My GReddy boost gauge, the stock gauge, and the JDM map ... none of them agree. Even in vacuum.
Its annoying so I just go off the JDM map anyway. Come up with something cool.
I have a buddy that is very good with this kind of stuff. He normally comes in to run all the electronic side projects that come up. Are we after something that mounts like a gauge? Or just a small LCD display? I'll run it by him see what he can come up with. Personally I think something I can shove in my steering column mounted pod would be best for me.
Input?
Input?
We should be able to cook up a display for this. As one of the other projects he's working on for me is a meth controller that runs off the JDM map sensor. So it was an "on topic" thought anyway.
I dunno the gauge is a nice a idea but the digital display is nice seeing that your psi is displayed instead of having to read it.
Def a nice idea though. The AEM uego gauges are they seperate or do they go to a central controll unit ? Maybe they could use them if so might be easier could even contact aem there not going to care i bet.
The UEGO gauge just puts out what the chip somewhere in stream tells it to. And is configured as such. Without something in line to "tell" the gauge what to read. It won't just read what you want it to. It has to know how to interpret the data. The lookup table for voltage out - to psi has to be on a chip. Then it tells the display what to put out. So it will have to be specific to the JDM map sensor's voltage to psi scale.
Their 19 in 1 serial gauge could possibly do it. But it is driven off the AEM itself I believe. So what it reads out would be configurable to some degree. But - if you have an AEM... you probably do not have a JDM map sensor... all things considered.
it would be nice to have an open source serial data guage. that way we can drive it directly from the ECU.
i am currently building my own gauge to monitor boost and afr.. a la zetronics.
i have spent about 70 bucks on the hardware and lcd so far, and i am currently writing the code.
the jdm sensor spits out a 5v signal as does the output wire from my innovate WB.
My hardware [adruino board] has 6, 5v inputs with a built in ADC for conversion.
I have boost, peak boost, a boost graph, two warning levels [set at 20 psi and 24psi], and similar functions for afr. I am displaying it on small two line red lcd. In the end, this will have costed me less than 100 bucks for the hardware.. and a few weeks of coding.
lcd ... http://www.sparkfun.com/commerce/pro...roducts_id=812
hardware ... http://www.arduino.cc/en/Guide/Introduction
BUDLoNG
BUDLoNG
BUDLoNG
BUDLoNG
Is there any chance of hooking it up to an analog style gauge for those who prefer that visually.
its a programmable micro chip with both digital and analog outputs. I dont see why it couldnt easily be hooked up to an analog gauge. My project isn't going in that direction, but ill add it to my list of things to do.
depends on when i get thru GTA IV
it's just coding at this point and then hookup, so i would assume around a month.
i am using an old parallax bread board to hold my potentiometers [to simulate the boost and afr inputs].
