Higher than 319 boost limit
I would like to use higher than 319 in my boost limit table. How hard would it be to come up with a patch or add to an already popular patch? (hint: the popular one has a 5 in it's name). I do not write code so please explain this to me in layman's terms.
Thanks
Thanks
ok for 88590015 add
Now change the "Boost Limit Dbl" table from 0x6DDD to 0x4D00.
Also change your "LoadBoost" scaling from
to
Note the toexpr, frexpr and max changes.
Let me know how/if that works.
Cheers
D.
Code:
<table name="Boost Limit Dbl" category="Turbo" address="15cc4" type="1D" scaling="Hex16"/>
Code:
<scaling name="LoadBoost" units="%" toexpr="x*5/4" frexpr="x*4/5" format="%.0f" min="0" max="319" inc="1" storagetype="uint8" endian="big"/>
Code:
<scaling name="LoadBoost" units="%" toexpr="x*10/4" frexpr="x*4/10" format="%.0f" min="0" max="638" inc="1" storagetype="uint8" endian="big"/>
Cheers
D.
HMMM could this be used to reduce the maximum timing retard limit???
at addresses 173f for 90550001 and 133f for rom 88570008
at the moment when its set to 255 the max limit is -10
could this get us down to -20 ???
ANTILAG
ANTILAG
franzcars
Jul 26, 2023 09:27 AM
