car stalls with a/c on - Page 5 - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
EcuFlash
Sponsored by:
Sponsored by:
Old Aug 2, 2009, 11:44 PM
  #61
Appauldd's Avatar
Yes, I found them all on here.
Appauldd is offline
Old May 15, 2017, 06:37 PM
  #62
Bmurray's Avatar
Can someone help me. Instead of making a new thread I am just going to ask here. So I had a iacv issue last week. Basically, I thought mine was bad, so I bought a cheap eBay one, cheap eBay one came in and I was having an erratic idle so I messed with the biss screw. I said screw the cheap eBay iacv, cleaned my oem one good and put it back in. I also turned the biss screw back a few turns to where it was. Ever since then, whenever I turn my AC on, the car stumbles horribly and eventually shuts off. What in the hell could have happened? Car runs perfect with AC off, as soon as I turn it on, dies.
Please help!
Bmurray is offline
Old May 16, 2017, 01:22 AM
  #63
Just back off the biss screw a bit, then a bit more.
Do you have an atmo BOV?
RightSaid fred is offline
Old May 16, 2017, 02:36 AM
  #64
gsrboi80's Avatar
Please help!
Was the battery disconnected at the time? The Evo ECU will need to relearn idle settings for both AC on and AC off, this takes a few drive cycles to complete. Also, when you "adjusted" the BISS did you do so using EVOSCAN actuator section to turn off the ISCV, set it, then re enable the ISCV per the FSM, if not I'd go back through that procedure and set the Base Idle correctly.
gsrboi80 is offline
Old May 16, 2017, 04:46 AM
  #65
Bmurray's Avatar
Yes but I am on speed density. Okay I will try that
Battery was never disconnected. Alright thank you looks like it all just needs to be reset in evoscan and via biss screw
Bmurray is offline
EvoInSoCal
24
Mar 10, 2018 11:07 AM
lando524g
Jan 24, 2018 07:43 AM
simple_lancer
EcuFlash
73
Aug 12, 2017 05:26 PM
clanzkiller
25
Mar 15, 2017 09:55 PM
irwintan27
Nov 10, 2016 09:37 AM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
