Question about 2-Byte Load and MAF Scaling
I have searched and could not find a definite answer to this question. Does scaling the MAF change 2-Byte load values? If so, would decreasing the scaling, increase the load?
My current MAF scaling is reduced by 14% from 100 - 1600. I am hitting 300 load at 3500 RPMs @ 25 psi on a 20g-9-5. Does this sound right? Should I set the high load areas on the MAF scaling (500 and above) back to stock and just smooth the values to make the curve look good? Any feedback would be welcome, Thanks
Edit:
Just running some quick numbers in the equation, I get:
BoostEst=[(load*T)/(P*VE*280)]-14.7
T = actual intake air temp (not MAF temp) in degrees Rankin (degrees F +460)
P = atmospheric pressure in psi at the MAF(baro)
VE = VE of engine at the RPM being measured
https://www.evolutionm.net/forums/sh...d.php?t=307894
(300*520/14.7/.90/280)-14.7=27 psi
I used an intake temp of 60F (not sure what your temps are like where you live now or if the loads are at night, etc
I used a VE of 90% at 3500 RPM
The quick approximation comes pretty close, so I would say it sounds about right.
Changing just the VE to 95% makes the boost estimate right at 25 psi. I know our engines/setups for this equation are right at 100% around 5k or so, so 95% at 3500 may be reasonable with your setup. Either way, I think this shows you are about right.
