disabling lean spool
This is odd b/c i'm looking at my rom, stock rom, and tephra pre-patched rom and the all have "0" for bit 7 (FBA) ... does that mean by default it is disabled?
I'm using 90550001 rom, and fba was set to 0009 (bit0 and bit3 active, lean sppöl enabled) switching to 0008 (bit3 active, leanspool disabled) won't disable leanspool. AFR stays the same.
Setting start leanspool and stop leanspool to 2500 made slightly lower AFRs.
Please forgive my ignorance. I think Lean spool is disabled on my now 015 teprha 5.10 patched ROM, when I had 008 I had no problems at all. Now that I switched over to 015 my MPG sucks and my wideband maxes out at 10.0 when i give it slight gas to maintain speed. I am assuming that is caused by disabling Lean Spool, if it is how do I put it back to "normal" or do I need to re-tune my whole car???
