Ecuflash Error
Registered User
Ecuflash Error
i have an 06 JDM Evo IX. when i connect to Ecuflash it is not working for some reason!
an error message comes up, and the log says:
[13:10:16.484] Version 1.34.1435
[13:10:16.484] 11 memory models read.
[13:10:16.484] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[13:10:21.046] 242 ROM metadata models scanned.
[13:10:21.046] checksum module "subarudbw" loaded.
[13:10:21.046] flashing tool "wrx02" loaded.
[13:10:21.046] flashing tool "wrx04" loaded.
[13:10:21.046] flashing tool "sti04" loaded.
[13:10:21.046] flashing tool "sti05" loaded.
[13:10:21.046] flashing tool "mitsukernel" loaded.
[13:10:21.046] flashing tool "mitsukernelocp" loaded.
[13:10:21.046] flashing tool "shbootmode" loaded.
[13:10:52.968] Using interface OpenPort 1.3 Universal TX27NF9#176335d59c761ad1529e421a7bf6b516833b07fa
[13:11:01.656] sending init sequence 1 (0001)
[13:11:04.875] sending init sequence 1 (0003)
[13:11:08.109] sending init sequence 1 (FFFF)
[13:11:11.359] sending init sequence 1 (F0F0)
[13:11:14.093] no response to any known code
[13:11:14.093] interface close
is it possible my ECU is "locked".
Please advise. Thanks in advance.
Registered User
Yes it seems that your ecu is locked , did you use Ecu unlocker yet???
will the car be able to start even though the ECU is locked?
i am currently rewiring my car and for some reason all i get is tumbling. i am starting to think its the ECU.
If the ECU has been professionally tuned previously, it's pretty likely it's locked. All the lock seems to do is change the init value so that ECUFlash can't read anything out of it. The locked ECU would not affect how the car runs.
Use the unlocker and then change the init code to 0001 and you should be able to use ECUflash without the unlocker in the future.
Registered User
so any Evo IX Ecu will be able to start another Evo IX? without any problems?
Thanks again
jmcmill3
Nov 22, 2009 12:13 PM
