94170015 work for all 03-04 Evos?
#46
I made the switch from 0008 to 0015 and it runs good, mostly
I get very annoying knock as soon as I excellerate, the CEL light is flashing like crazy. This is the same tune I used from 0008 as well.
#50
I too have the annoying knock flash at around 2400 RPM.
I turned up the down the knock sensitivity, but I still get 3 counts but only at WOT.
Timing does not get pulled so I just ignore the flash.
Oh and lean spool is disabled.
#53
Yep I disable lean spool and it dropped AFR by almost a point. Used the same method as Appauldd. I found it in a thread i searched here on the forum. I'll try and find it and link it here is anybody needs it.
#55
#57
Bink, I'm not selling them any more. I'm too busy with my real job and hacking the Evo ECU. :-) There's a group buy in the ECUFlash thread, and you can also get them from mitsubishiparts.net. Just ask for the Evo X MAP sensor. Its the same as the JDM Evo 9 MAP sensor.
#58
OK so the 03s should stay with the 94170015. Got it!
I think anyone with the 94170008 and 94170014 should upgrade to the 0015 just for the sake of eliminating the 008 and 0014 questions/issues.
For the sake of helping our wonderfule coders....please stick with the 0015.
#60
1 Post
Its for late model '04s. It won't work on early '04s without some other tweaks as tephra mentioned.
Sounds good to me, I will check that out. Thank you for helping me out!!
-Bink
