CEL P1400 after VSR intake install??
Im getting this code after the install of the AMS VSR intake... I still have the sensor plugged in as i was told to do and just sip tied up under the intake as theres of course nowhere to put it ont he VSR... but its pulling this code still. Do I even need this sensor or can i disable it? And if I can disable the CEL light for it how would I go about doing it? I have disabled my P0300 misfire code using the binary bit mod on my ECU. Can I do the same for this sensor and where would it be located?? Any help is greatly appreciated. The CEL in my face non stop is drving me nuts!!
you need a map sensor adaptor that ams sells (part number SKU1801) its a adaptor that your map sensor bolts to then you simply run a hose from the adaptor to a vac port on your monifold.
I cant help you with this, but i can add a +1 to the problem. Ive also installed the AMS intake manifold and i now get Misfire errors as well. Ive also found it hard to get the idle running smooth after adding this intake.
I know its not the best section or thread, but have people found they don't really need to upgrade the intake manifold to make 600+whp?
Sorry for the highjack
EvoM Community Team
If you do need a MAP adapter PM me... I have an extra left over from my 2g I'll sell for half price (barely used if ever).
As for the code, the OBDII database shows it as "P1400 Heated Catalyst Battery Voltage or Current too Low During Heating (Bank 1)". I don't know if that is the correct code or what sensor you are talking about as (very unfortunately ) I don't have any experience with the VSR aside from oogling.
DormantBeast
13
Jul 9, 2017 07:38 AM
