94170015 and evo7base with mods
I wanted to let everyone know that I uploaded my files to the Wiki if anyone wants to see modded xml files.
Mods included are...
Tephra v5.10
MAP to MAF (work in progress)
OBD II codes
Post Primer fueling
Decel Fuel tables
Airflow Hz and Temp Comp table
Idle sensitivity control
Corrected Idle Stepper table
Thermo Fan tables
MUT table
Knock Filter tables
Periphery bits
I organized then so that like items are grouped by category "type". I also took the evo7base and added all of the scalinngs. The evo7base file was also grouped and titled according to the grouping.
I did this because I was tired of trying to find certain tables so I grouped them.
Be advised....these xml files also include the MAP to MAF patch. This patch is still a work in progress so use with caution.
Here is how you get to the files....
Go to the Wiki.
left side in the Tool box is "Upload File" Click it
in the text you will see "list of uploaded files" Click it
My file should be the 1st one. Same SN as on here.
Tephra v5.10
OBD II codes
Post Primer fueling
Decel Fuel tables
Thermo Fan tables
MUT table
Knock Filter tables
Periphery bits
Go to the Wiki.
Last edited by Appauldd; Feb 6, 2009 at 08:09 AM. Reason: added info on how to get the files.
For those without a login/username:
http://evoecu.logic.net/wiki/Special:ListFiles
It shows all the uploaded files.
Scroll down to see his file.
Direct link to that file (v5.10):
http://evoecu.logic.net/wiki/File:94...v5.10_MODS.zip
A newer version (v7) is here:
http://evoecu.logic.net/wiki/File:94170715-v7.zip
thread revival.
If anyone needs the evo7base.xml and the 94170015.xml with the tephramods, and also direct ecu based boost control, and a bunch of other stuff and it actually works in EcuFlash. I made it myself, so here you go.
http://evoscan.com/index.php?option=...5_plus_alotxml
just scroll down and its below the old versions of EcuFlash.
mrfred
Sep 14, 2022 07:08 PM
mrfred
Feb 26, 2022 06:16 PM
scheides
Oct 22, 2021 08:59 AM
