EcuFlash
Problem with ecuflash 1.41
Old Feb 7, 2009, 12:30 PM
Cyloc's Avatar
ok...I tried to write to the ecu several times. Finally got the idea to have my wife hold her foot on the gas. Finally found a point of voltage where the program would write to the ecu. I got the battery to 12.5 volts. Suddenly it wrote. Just to test this theory i tried again at 12.4 volts. It would not write. Tried several times at voltages under 12.5. Then tried again at 12.5 volts. Worked like a charm. Did it a few more times at 12.5v and would write.
This voltage issue should be something that should be looked into. The progrm should operate at 12.0 volts not 12.5. It makes sence that one of the guys said that 90% of the time you have to have the car running and let ecuflash shut the car off. While the car is running it holds 14 volts bc of the alternator charging. It takes about 1 to 2 minutes for the car to go back to 12. Hence why the program will write.
Cyloc is offline
Old Feb 7, 2009, 01:49 PM
06EvoIXmr07's Avatar
I didnt have this problem with the older versions of flash just this one.Its sensitive to the volts for some reason.Glad to hear you got it worked out.
06EvoIXmr07 is offline
Old Feb 7, 2009, 02:44 PM
Wicked E's Avatar
Yep, never had this issue before this version. I am so glad you got it working buddy!!
-E
Wicked E is offline
Old Feb 7, 2009, 03:58 PM
gsrboi80's Avatar
Glad you got it running bro. Glad I could help
gsrboi80 is offline
Old Feb 7, 2009, 04:02 PM
Sean@Iveytune's Avatar
edit
Sean@Iveytune is offline
Old Feb 7, 2009, 09:54 PM
codgi's Avatar
There might be a set reason to only have it work above 12 volts, I doubt it was just put into the program by chance.
You running a mini battery when you conducted these tests?
codgi is offline
Old Feb 8, 2009, 06:27 AM
Cyloc's Avatar
Nope. I have a full size 800 cranking amp battery.
Cyloc is offline
Old Feb 8, 2009, 07:26 AM
WRC-LVR's Avatar
Clean the terminals off to bare shiny metal, both cable and battery. I think the battery is not getting a full charge when being ran. Does the car sit for most of the week ?
You can do a drop test to check the battery under load too. It may be one weak cell in it.
Glad to hear you got it flashed...good work on testing for voltage. The older versions of EcuFlash would try even if the voltage was a little low, and would scramble the rom. Probably Colby tried to ensure it would not happen. Obviously it checks, but if the voltage drops during the write, then you have an incomplete write..same scenario
I never had an issue until last week and tried to flash a cold car that had sat overnight at 25F. Would not read the rom off the car. Started and warmed it up and it was fine. Has to be slightly low voltage.
rule of thumb....start it and get the battery charged first
WRC-LVR is offline
Old Feb 8, 2009, 04:01 PM
codgi's Avatar
Fair enough. The highlighted below is more why i could see them having this implemented (i.e it not being by chance)
Anyway once you got it charged thats the important thing and now people know to look out for this in the future. YOu could optionally roll back to an older EcuFlash once you don't need any functionality from the newer ones but then you run the risk of the highlighted above I suppose .
codgi is offline
Jorge T
EcuFlash
48
Feb 8, 2010 04:50 PM
VR4PLAY
EcuFlash
Jun 18, 2009 07:07 AM
PPM
EcuFlash
11
May 26, 2009 10:23 AM
BonsaiScott
EcuFlash
Mar 27, 2009 08:17 PM
Shadowpriest
EcuFlash
Feb 23, 2009 02:06 AM
Quick Reply: Problem with ecuflash 1.41
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
