EcuFlash
Cranking enrichment
Old Feb 12, 2009, 04:56 PM
THUB's Avatar
Cranking enrichment
Hey all, I've made the switch to E-85 and so far I'm enormously impressed with what the stuff will do. My problem is that here in chicago, it's damn cold and the car will barely run for the first minute or so after it's started in the morning. I read about a cranking enrichment table the should be in ECUflash, that is supposed to eliminate the problem, but my version of ECUflash does not have it. Does anyone have the definition for the cranking enrichment table that I could paste into my current version?
THUB is offline
Old Feb 12, 2009, 05:34 PM
EvoM Super Moderator
fostytou's Avatar
https://www.evolutionm.net/forums/ec...ent-table.html
Hi from Palatine
We can't be much help without even getting your romID. Searching for "start startup e85" got me right to the thread.
fostytou is offline
Old Feb 12, 2009, 06:07 PM
kkarim's Avatar
you probably need to reduce the values in your IPW adder table.
use the link above as a guide.
kkarim is offline
Old Feb 13, 2009, 10:04 AM
Use the IPW adder table to allow easy starting, but after the initial start it no longer is a factor. I am running E85 in Midwest IL and car starts in -15 degrees, but is very sluggish the first few minutes. I did adjust my coolant temp for open loop and that helped a bit.
fixem2 is offline
Old Feb 13, 2009, 10:07 AM
This thread may prove useful to us : https://www.evolutionm.net/forums/ec...discovery.html
fixem2 is offline
Old Feb 13, 2009, 10:31 AM
fostytou's Avatar
There is a timing trim vs coolant temp map. When running E85 I usually have it trim MUCH less timing in the <30*f areas and it helps a ton with the sluggishness.
fostytou is offline
Old Feb 13, 2009, 10:40 AM
Can you post your settings? I haven't seen that table yet.
fixem2 is offline
Old Feb 13, 2009, 12:03 PM
fostytou's Avatar
The defs for 88590015 are in the newest ECUFlash included XML. If you don't want to download it I believe there is a thread on here with some of the definitions.
(OE values left, mine right)
Also note, I had to actually raise the cranking IPW, but I only have 780cc injectors right now. There is a formula in the other thread for getting the correct values.
fostytou is offline
Old Feb 14, 2009, 09:06 AM
THUB's Avatar
My ROMid is 94170015. I guess that would have helped to add originally.
Also, Hi fost. I've never noticed you were in IL despite learning quite a bit from your questions on other threads
THUB is offline
Old Feb 14, 2009, 11:28 AM
Wicked E's Avatar
I see you are not using the 1.3* factor for any of your IPW values.
Your values are way over what I have just using the 1.3 factor. What was your scaling?
-E
Wicked E is offline
cheb evo
E85 and Ethanol
Sep 16, 2010 04:31 PM
David Buschur
EcuFlash
29
Sep 8, 2010 12:34 PM
EriCS
EcuFlash
Jun 5, 2010 03:50 PM
wip
EcuFlash
11
May 17, 2009 06:09 PM
Charlie_B
EcuFlash
12
Oct 15, 2008 03:16 PM
Quick Reply: Cranking enrichment
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
