TephraMOD V6 - testing!
Old Feb 26, 2009, 03:05 PM
  #31
nonschlont's Avatar
Originally Posted by tephra
in 2.5+ they need to go in the "<Mode2 name="Mode2" type="Data List Items">" section...
in answer to the previous Q about 1.2 v 1.3. Sorry the ROM is still setup for 1.2, but my XML is 1.3 (I use 1.3 in my ROM... and I just copied the XML from my evoscan... oops)
cheers to you sir! If I remember correctly I put it in the last line of the fist section above it...
Old Feb 26, 2009, 04:22 PM
  #32
mrfred's Avatar
Originally Posted by MR Turco
tephra, when you produce the 88590015 version can you just verify if mrfred's SD tables fit?
I can tell you already that it will work. The SD patch overwrites existing code that had nothing to do with tephra ROM mods.
Old Feb 26, 2009, 04:35 PM
  #33
cossie1's Avatar
Nice work dave.
Another waiting quietly for 90550001
Old Feb 26, 2009, 11:47 PM
  #34
nonschlont's Avatar
turns out I had it in the right place after all... I have tried placing at the top and bottom of
<Mode2 name="Mode2" type="Data List Items"> section. and still nothing
Old Feb 27, 2009, 01:35 AM
  #35
Dragon-V's Avatar
Originally Posted by cossie1
Nice work dave.
Yep another waiting quietly as wel
Cheers
Lee
Old Feb 27, 2009, 04:42 AM
  #36
SkyNight's Avatar
88580014...MMM if you want Dave, I can test it for you
Old Feb 27, 2009, 04:04 PM
  #37
Vigman's Avatar
Wow!!! Can't wait to see the 88590015 release !
Thanks Dave!
Old Feb 27, 2009, 04:18 PM
  #38
THUB's Avatar
Any chance that you'll make a 9417**** version still? I know it's been giving problems
Old Feb 27, 2009, 06:58 PM
  #39
tephra's Avatar
yeah 15 is on the cards...
Old Feb 27, 2009, 08:31 PM
  #40
fixem2's Avatar
Thanks for all the work Tephra, looking forward to V6 when the car gets back. Donation sent.
Old Feb 28, 2009, 01:16 AM
  #41
al\lupo's Avatar
One question about gear dependant boost: what does the 0 (zero) gear means?
Old Feb 28, 2009, 01:31 AM
  #42
SkyNight's Avatar
Also "RPM/Speed Ratio Filter Strength" measured in units.
Old Feb 28, 2009, 02:45 AM
  #43
tephra's Avatar
0 gear should be standstill + engine running.
u should need to change the filter strength...
Old Feb 28, 2009, 06:56 AM
  #44
THUB's Avatar
Awesome. This news makes my whole week.
Did anyone ever figure out what was going on? I observed tip-in knock when I switched, but I pulled a degree of timing from that area and it went away AFAIK
Old Feb 28, 2009, 10:14 AM
  #45
EvoM Community Team
fostytou's Avatar
Sounds like it was probably real knock then....
Quick Reply: TephraMOD V6 - testing!
