TephraMOD V6 - testing!
Old Feb 28, 2009, 07:23 PM
  #46
tephra's Avatar
yeah not sure!
due to the intermittant nature of this problem i wouldn't be too concerned.
if you were consistantly getting tip-in-knock then logs of modded vs stock rom would be appreciated
Old Mar 1, 2009, 10:44 AM
  #47
mlocatel's Avatar
Hello Tephra
the first test did not work . After reflashing I couldn't start the car.
I sent you per E-mail my rom. Perhaps I made mistake with your options.
BR
mlocatel
Old Mar 1, 2009, 11:37 AM
  #48
evodood's Avatar
Subscribed.
Old Mar 1, 2009, 12:40 PM
  #49
SkyNight's Avatar
Originally Posted by mlocatel
Hello Tephra
BR
mlocatel
Do you check the immobilizer code?
Do you check the value of valet mode?
Old Mar 1, 2009, 12:53 PM
  #50
mlocatel's Avatar
Of course
The valet is disabled, immobilizer is ok
Old Mar 1, 2009, 12:59 PM
  #51
Yorgis_MR's Avatar
Tephra, how can we contact you? I have an almost-stock MR and I need the 96940011 ROM along with some Q&A (perfectly willing to support the cause, of course). If you have the time for it, I would appreciate it.
Old Mar 1, 2009, 02:10 PM
  #52
EvoM Community Team
fostytou's Avatar
I'm not sure how many people you PM'ed, and we're all here to help... but if you are just starting there is a sort-of minimum amount of reading that is a "barrier to entry". See my PM with the ROM info that you need to switch to and possibly look into the "how to tune an evo" thread. There is also a link in my sig for the stock ECU tuning Wiki that may be helpful.
We can all walk you through it step by step, but all of the information is really here already. One way or another you are going to have to read it, but the more you read and understand the better off you are when any possible problem might arise.
As always, back up your original rom in multiple places before flashing anything.
Old Mar 1, 2009, 02:11 PM
  #53
taavisev's Avatar
is there big difference between 88840017 and 88840617???
thanx
Old Mar 1, 2009, 02:20 PM
  #54
SkyNight's Avatar
thanx
Yes, there is a VERY BIG difference. 88840617 has a Tephra MOD!
Old Mar 1, 2009, 02:22 PM
  #55
SkyNight's Avatar
Of course
Which is the ID of your stock ROM? You have an EVO IX MR...
Old Mar 1, 2009, 06:43 PM
  #56
recompile's Avatar
thanx
88840617 is not an official mitsu ROM version. Tephra took 88840017 and altered his v6 ROM to identify itself as 88840617. The reason is because EcuFlash loads up different XML for different ROM versions, and by making a completely new ROM version, Tephra can provide a completely custom XML for that version that includes all of the options for his v6 ROM.
Essentially, it limits the likelihood of XML screw ups, because without his new XML, the ROM won't load into EcuFlash.
Old Mar 1, 2009, 09:51 PM
  #57
mlocatel's Avatar
Hello SkyHigh
The ID is correct. I have original 88840017
mlocatel
Old Mar 1, 2009, 09:55 PM
  #58
tephra's Avatar
I took a look at your ROM.
Can't see anything obvious that's wrong.
What does the car do? no start? start but run bad and die?
Old Mar 1, 2009, 11:07 PM
  #59
nonschlont's Avatar
has any1 added the new defs. that Tephra provided for evoscan? I have added it to " <Mode2 name="Mode2" type="Data List Items"> " directly under this line and no new data items... I dont know what going wrong here
Old Mar 1, 2009, 11:08 PM
  #60
tephra's Avatar
email me the full xml and I will check it out
myforumname @ gmail (dot) com
Quick Reply: TephraMOD V6 - testing!
