TephraMOD V6 - testing!
#691
Just found the info I needed for the 2byte to 1byte load scaling:
https://www.evolutionm.net/forums/ec...-load-mod.html
I made mine 1.3 because I see around 320 at peak torque and this means my scaling should be able to handle around 330.
Great work
However, can you provide us with what MUT values we should log for what? I am afraid I will still get weird airflow numbers....
Great work
#693
Well just got back form testing and no luck at all.
I copied al my tables over into the 96530706 ROM supplied - including my immobilizer code, and flashed my Evo8 AUS/SA 96530006.
Car cranks but it just refuses to start. I have checked an cinfirmed umpteen times that the immobilizer code is correct.
See pic below.
What I am doing wrong?
Thx
Edit:
If I flash my car again with my original ROM 9653006, (the same one which I copied the tables from and pasted into 9630706) , the car starts fine.
See pic below.
Thx
Edit:
#695
"Valet Rev Limit " = 114 rpm
Car still won't start
So for the hell of it, I changed the Valet Rev Limit to 3000rpm with Valet Mode disabled, car won't start.
So I then enabled Valet mode, with the rpm limit still set to 3000rpm, turned the ignition on and held the throttle to the floor for at least 10 secs, and noticed that the Engine light wouldn't flash. which makes me think that it didn't kick over to Valet mode.
Not sure if that is a seperate issue or somehow related to the car also not starting.
FWIW, Valet mode works fine with my old ROM and 5.12 patches.
#700
valet = 0
Valet rpm limit = 3000
Car won't start.
Ecu flash 1.41
Endian = big
Using in conjuction with Evo7base_20081101
#701
Ok, all I will do is change the immobilizer code to mine, and then flash the car with the ROM that came with V7t5.
#704
