Links to jcsbanks' Speed Density patches
#46
What is not OK on the screenshot is your endian. You need to change it from little to big for the MAP VE table and its scalings if you are using later than Ecuflash 1.29a.
#49
I, too, would love an SD patch for this ROM. Maybe ask mrfred about it or perhaps he responds here if he reads it. From what I understood, you will need to first at least have the MAT fuel temp patch and have the boost logging in place.
I will be happy to take a look at a patched versus non patched ROM for some other ROM and see if I can compare it to 96530006, but I doubt I will be able to port it over. I think I remember mrfred saying that's it pretty complex.
Eric
#50
I think mrfred was just about to do this a while back untill he got sidetracked on a few other big projects.
Eric
Eric
#54
If you look at one of the other ROMs that are posted you will see that there is a field called "SD Convert IAT to MAT (0x03 -> 0x0E)", if you leave it as 03 it will continue to log through the MAF input.
#58
Yes, bribe mrfred to do it! I was talked into it by Eric when I realised 94170015 was already done, and I've copied mrfred's schema and was about to start doing it for 9653, but it is rather different to the method I used on the JDM ROMs so I haven't been able to get to it yet...
