Internal Id Numbers
Old Mar 15, 2009, 10:06 PM
Stradag's Avatar
Internal Id Numbers
I did a search but I can not find a clear answer. I see alot of poeple refering to the internal ID numbers the one my car came with was 94170008, I reflashed it with a ROM with internal id number 94170015. My car seemed to run fine, is it ok to flash in ROMS with different internal id numbers?
Old Mar 15, 2009, 10:13 PM
SICK9's Avatar
I wouldn't do it..
If anything, I would think some of the parameters or xmls would have to be changed.
But I'm sure all the experts will chime in and let ya know.
From what I can gather, you can do it, but some stuff has to be changed.
Old Mar 15, 2009, 11:59 PM
codgi's Avatar
Certain roms are more or less interchangeable and many people have done it with no issues so far.
I personally wouldn't do it unless the new rom had a feature/solved a problem that i needed taken care of.
Old Mar 16, 2009, 12:09 AM
tephra's Avatar
if the first 4 digits are the same then usually the rom's are interchangeable..
however "if it aint broke..................."
Old Mar 16, 2009, 05:44 AM
Stradag's Avatar
Basically I downloaded this rom from aktivematrix.com because it had the po300 misfire code fix in it. I havnt had a check engine light since I did the reflash, but I wanted to make sure it was ok to have this Rom before I went and had a tune done. The only difference I noticed is I hit fuel cut with this rom because I think it is stock.
Old Mar 16, 2009, 01:33 PM
SICK9's Avatar
Tephra is the man..
His word is golden when it comes to this stuff..
Thx for the clarification..
good luck stradag
Old Mar 16, 2009, 03:37 PM
tephra's Avatar
Stradag - you need to copy any of your tuned maps across when you do it
Old Mar 27, 2012, 01:56 PM
Frew's Avatar
Zombie thread!!!! What is the bare minimum you have to copy of to make the rom work? Immobilzer? etc?
REV.olution
Apr 13, 2011 01:43 PM
eastxcelerate
Jun 3, 2010 01:42 PM
fid
Jul 13, 2008 11:39 AM
Magnumpsi
Aug 9, 2007 04:28 AM
Dero
Sep 14, 2006 01:35 PM
Quick Reply: Internal Id Numbers
