What's the difference between "PATCH: NLTS + Valet + KnockCEL" and "Tephra Mods"
The reason I'm asking is the PATCH: NLTS + Valet + KnockCEL has my 96940011 Roms but the Tephra doesn't have it.
that was the original tephra mod.
Later mods only supported more common roms. if you don't specifically see your rom there is probably a version of it that is supported. Look to see if the first 4 numbers of supported roms. they are usually compatible but make sure you investigate before flashing.
OK. I know I can use the JDM Roms for 05 but that require disabling the immobilizer and I'm trying to avoid that. Beside this are all I need. I actually just need to monitor my knock without using the laptop.
If you want just the Cel-on-Knock, try here: https://www.evolutionm.net/forums/ec...ded-knock.html
96940011, difference, disable, evolutionm, jersey, knock, knockcel, mod, mods, nlts, patch, tephra, tephramods, valet, whats
