ISCV control system disassembly
#136
I logged Mut 08 and 0A earlier today, using the same formula as the fuel trims...but I don't know what exactly it tells me. Both numbers were positive, and about 5 or so....I was guessing that meant that it was adding 5 steps, but I removed 5 steps and the number barely changed.
#137
#139
#143
I don't mean to jump the gun, because you still haven't gotten it all fleshed out...but what will knowing ISCV demand tell me (and anyone else whose logging it)? Will it help know what to set the ISCV adders to or will it just confirm a specific demand but not necessarily tell if it's higher or lower than you'd like?
...or do you not know until you log it, lol?
#145
The EvoScan formula for the ISCV Demand trims is Eval="100*(x-144)/255".
EDIT: Example EvoScan entries would be:
<DataListItem DataLog="Y" Color="" Display="ISCV Demand Trim AC off" LogReference="ISCVDemandTrimACoff" RequestID="08" Eval="100*(x-144)/255" Unit="% Demand" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-16" GaugeMax="16" ChartMin="-16" ChartMax="16" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
<DataListItem DataLog="Y" Color="" Display="ISCV Demand Trim AC on" LogReference="ISCVDemandTrimACon" RequestID="0A" Eval="100*(x-144)/255" Unit="% Demand" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-16" GaugeMax="16" ChartMin="-16" ChartMax="16" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
