ISCV control system disassembly
Old Feb 23, 2019, 08:03 PM
  #436
nor11384's Avatar
wait a minute thats a new one...can you elaborate on that?...i thought the only table that was wrong and uses demand instead of steps is the stepper lookup table...This is what i got...did you just rename your tables as you figured out which did what?
Old Feb 23, 2019, 08:16 PM
  #437
kaj
kaj's Avatar
I think I read about someone recently making a patch to allow for more ICV adjustment. Most of us have none of that stuff.
Old Feb 23, 2019, 08:42 PM
  #438
nor11384's Avatar
Interesting. I want. What rom do you have? I’m on 9417.
Old Feb 24, 2019, 02:30 AM
  #439
Evo_Jay's Avatar
I took a very long time and used this thread and the old tables and lots of testing and put together my own .xml for the idle/iscv section.
The pic I posted is of my 9417 .xml
Old Feb 24, 2019, 02:31 AM
  #440
Evo_Jay's Avatar
There's no patch. Its just adding the proper tables to your .xml and organizing them well. All the table info is out there, its just spread out and not all in one place.
Old Feb 24, 2019, 08:58 AM
  #441
nor11384's Avatar
I figured that’s what it was. I’ll never have time to test each one and figure them out. Care to hook a brother up with those tables?
Old Aug 1, 2022, 06:05 AM
  #442
Biggiesacks's Avatar
@Oscar32 you need to find the definitions that match your ROM ID. The addresses of the tables are different depending on your ROM ID. So you have to find the definitions specific to your ROM ID. If pasting definitions into your XML causes it to not work, then you need to check for syntax errors. It's code, so any little wrong thing can cause it to not work.
Boosted Tuning
Aug 26, 2023 10:14 PM
tephra
69
Dec 17, 2022 04:59 AM
simple_lancer
Oct 14, 2020 02:18 AM
ziad
Jun 11, 2017 12:38 PM
Dynotech Tuning
Sep 20, 2016 01:30 PM
Quick Reply: ISCV control system disassembly
