OmniPower 4 bar settings
Old Aug 12, 2009, 01:44 PM
  #61
mrfred's Avatar
Originally Posted by D-VO
After installing the omni 4 bar and implementing the proper changes found here and on mrfred's thread, I have found that I'm getting a bad lean condition after boosting then adjusting the throttle back slightly, but still boosting. I loose power, it stumbles for a second, then the afr goes back to normal, all while having the throttle in the previous adjusted position. Can anyone help?
Are you using the settings in my new thread on the OMNI 4 bar? What ROM are you using?
Old Aug 12, 2009, 08:58 PM
  #62
D-VO's Avatar
Ah! Didn't know you made a new thread. I'm using 96940011. In comparison to the jdmmap settings, I've noticed the only differences are in the "Map comparison" and "Map vs Maf". Did I miss anything else?
Also, I'd like to understand how this sensor works. For what reason does the map scaling voltage end at 3.63? Shouldn't it read upto 5 volts? Or is that because all units above 3.63 volts are supposed to be 255? Thanks.
I'll try these new settings tomorrow and hope for the best! Thanks a lot!
Old Aug 13, 2009, 03:34 PM
  #63
D-VO's Avatar
Eh...unfortunatly with these settings I'm still getting that lean condition after boosting. Is there anything else I can try?
Old Oct 26, 2009, 06:48 PM
  #64
Slo_crx1's Avatar
There's too much good info in this thread to just let it fade away...let's keep it up near the top now that Tephra's v7 SD patch is released.
Old Oct 26, 2009, 06:53 PM
  #65
JohnBradley's Avatar
Originally Posted by 97TSiAWD
Bringing this topic back. Did the MAP sensors get added to your store? Maybe I am looking in the wrong sections, but I don't see them in the Electronics section.
Thanks for all the information in setting this up. I'm looking forward to being able to log boost soon.
Our store has been plagued by issues If you would like to order these we stock them at all times and only need a PM to get the process rolling
thanks
aaron
Old Oct 26, 2009, 06:55 PM
  #66
Most likely your MAPVE table needs some more tweaking. After that comes the ROM which gets very sensitive. I am curious if you are using lean spool or if it is disabled?
aaron
Old Oct 27, 2009, 05:57 PM
  #67
Slo_crx1's Avatar
Ok, I'm tuning the SD setup, and I've gotten my omni 4 bar map sensor scaled in on the Tephra v7 mod patch as close as I possibly can get to matching up with the stock maf values I logged the day before. Everything looks good as far as fuel table-wise, but I'm getting some stumbling due to both my LTFT Low and Mid being at -12.45% right now. What is the best way to bring them back in check to where I had them previously with the stock maf (at around the 2.2% mark for LTFT Low only)?
Old Oct 27, 2009, 06:01 PM
  #68
EvoDan2004's Avatar
a bit late but i ordered my OMNI 4 bar and AIT from JohnBradley and got the best pricing and shipping was EVO fast. thanks man.
10isace
Mar 13, 2016 03:09 PM
JDavenport
Jun 14, 2013 09:47 AM
97gst_spyder
Jan 26, 2011 07:39 PM
scheides
Jan 12, 2010 03:09 PM
Quick Reply: OmniPower 4 bar settings
