help with jdm evo 8 gsr map 93660005
can someone help me change the tables from my gsr map(93660005) with the tables from the ralliart ecu(97250001) both maps are stock, and disable the immobilizer because i use push start button..(i only use car as track day car)? Bassicaly i want to run the 97250001 without immo
Thank you very much.
i've rescaled my tables for 280 and 300 load by replacing the 70 and 90 load lines, and modyfied all the tables (fuel ,map, turbo) like on 97250001rom , but the engine ran strange, wit a hesitation ,almost stall if you press fast the accelerator pedal at idle no mater if you are in gear or off gear, and had a similar hesitation if you go wot from 2800-3000rpm,.
when i read the 97250001rom a few tables seemd strange as the scaling on the turbo boost limit whic started from 1000 rpm to 5000, and on my rom and few others that i,ve studied goes from 4000up and few other diffrences, which make me belive i might have the rog definition for the 97250001rom and probably for the my 93660005rom
forgot to mention, the car is absolutelly stock
with my rom and just the turbo offset set to 80 from 60 and turbo limit ensreased with 25to 20 units in upper revs the car runs fantastic, but i still want to try that ralliart rom
is it possibly jus to flash that rom in my ecu without other changes aside imobilizer disable? is there any issue with the ecu id ore somethin else?
i'll put up bot the roms and xml as soon as i get home(out of town for two days), for you to check whether the ralliart rom is a ralliart rom or just som other evo 8 rom modified
rolly1818 got pm
thanks allot everybody
rolly1818 got pm
]<table name="Accel Enrichment" address="3864">
<table name="RPM" address="5b3e" elements="15"/>
</table>
so i already see a difference 3814/ 3864
i've just checked with the new adress and now the table looks ok , in fact is identical to ralliart rom, so i was right it was wrong before
everyone who has the deffinition that i had before should change it (as the one on lancer register, geekmapped, and here)
i'll try to upload the definition that i made with imob dissable , 2 byte table , and a few other corrections, but still there are a few problems with the base evo7 xml which i hawe in some 5 diffrent variants ,and we should all check them
almost done, still working on wastegate solenoid activation table, if i,ll make it work you can get the turbo to spool 300-500 rpm earlier, which is a lot, and in conjunction wit a 32 or 34 mm restrictor and som aother mods to the rom you can get close to 500nm around 2500-2800rpm, of course you loose some top end, but we don't drag our cars, but on a twisty road or track is unbelivable, curentlly runing 1.33-1.35 bar boost with 1.52-1.55 overboost, and runs perfect.
SOLVED the wastegate solenoid table,correct adress is "1a68" instead of 1668 ,1a66 or 166a
next are switchable maps , with a map with a lot of retard and enrichment (on overrun) for antilag in lower load cells and idle around 1800 rpm
