Patch: Force OBD Inspection Pass (acamus, mrfred)
#47
So let me get this straight. If I use Evoscan to clear my codes I can then install this patch and go directly to the emmission tester without driving for 75 miles for the ecu to reset and throw my p0121 and p0420?
Also, does anyone know why i cant save the file using notepad?
#50
bump.. still need an answer to this .. ^^^. i followed the video.. but t wont let me save the changes using notepad... in fact I have the same rom as the video so I did it step by step.
#51
When you go to save it, make sure you click "save as" and check the file name and have the correct file extension (XML). Some people have notepad plus or something like that and tries to save the file under a different name, instead of replacing the origional. You have to make sure you replace the origional (name and extension being correct).
#53
Sweet, now the only other question I have is why couldnt i save the changes i made using notepad... it wouldn't let me save the file after i modified it.
Quick question on topic.
I need to know where i can get these OBDII instructions for ROM 96420011...
Can any one give me a heas up?
Thanks in advance.
#54
Make sure the ECU Flash is closed when changing the xml.file. Or it will be utilizing this very xml you are changing, and then you opened it in another program, the original program locks it out so you can't overwrite the file and crash the program that is actually utilizing it. I learned that the other day, well, 10 years ago, but never let it get me till the other day...lol
Thanks in advance.
Thanks in advance.
#57
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
94170008
Non-Continuous Monitor Completion Patch
@36796 DA2A -> EAFF
@36798 6AA1 -> 6AA7
Non-Continuous Monitor Availability Patch Part 1
from 4019 to E000
Non-Continuous Monitor Availability Patch Part 2
from 6AA1 to EAFF
Code:
<table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="3677a" type="1D" level="1" scaling="Hex16"/> <table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="36790" type="1D" level="1" scaling="Hex16"/> <table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="36796" type="2D" level="1" scaling="Hex16"> <table type="Static Y Axis" elements="2"> <data>36796 </data> <data>36798</data> </table> </table>
@36796 DA2A -> EAFF
@36798 6AA1 -> 6AA7
from 4019 to E000
from 6AA1 to EAFF
Code:
<table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="36791" type="2D" level="2" scaling="blobbits"> <table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8"> <data>EGR system</data> <data>Oxygen heater sensor</data> <data>Oxygen sensor</data> <data>A/C system refrigerant</data> <data>Secondary air system</data> <data>Evaporative system</data> <data>Heated catalyst</data> <data>Catalyst</data> </table> </table> <table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="36797" type="2D" level="2" scaling="blobbits"> <table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8"> <data>EGR system</data> <data>Oxygen heater sensor</data> <data>Oxygen sensor</data> <data>A/C system refrigerant</data> <data>Secondary air system</data> <data>Evaporative system</data> <data>Heated catalyst</data> <data>Catalyst</data> </table> </table>
