Enabling mode23 illustrated
#46
Hi guys. To enable mode23 on newer ROM 52680022, is it all the same as for ROM 52680015 -> 52680020? So these below are the rows to copy into the 52680015.xml file?
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
Thanks!
Thanks!
make SURE the before value matches before you change it. if it does not match STOP and ask for the new definitions.
so for #1 when you open it the value should be '05' if it is not stop and ask. the same goes for the other 2 'before' values.
#47
it is the same process, but the xml will be entered into 52680022 unless that inherits from 52680015.
Pratically, the 52680022.xml file is created starting from the 52680020.xml, so at the end all inherit from 52680015: that's why I entered the xml in the 52680015 as usual. And, doing in this way, all the 3 "before" values are correct.
So, I think it should be ok.
#54
Hi guys, My Internal ID: 52690122 inherits from 5269022 then down to 52680015 and my 52680015 already has the code. The problem I ran into my before is not 0x05. I searched this thread for my 52690122 but was not successful. I already locked attempting to change the mode without "05" before this basically bricked my ecu I did successfully bench recovered it though
Thanks for the help.
#60
I have added the xml code but i cant see it in EcuFlash? My Romid is 53040007, i have added the code only to Inherits: evo10base map. Do i need to add it to 53040007 as well?
I have tried reopening ecuflash.
EDIT: i have added code to both evo10base and 53040007 roms and still no options in ecuflash
