TephraMod V7
#1516
unless you changed anything crazy from the VIII to the IX, i had already uploaded a IX SD rom...
Ill D/L this for comparison..
You guys are super though.
#1519
this XML is the one i patched for SD. I know it works, because i am running it now. It is basically the MOD788590715 w/ the JCSBanks SD patched in it. I can email you the Rom im using as well if you'd like to post it. The rom that downloads with the link you posted only shows the SD tables when i am using my XML, not with the one provided.
#1520
I finally fully tested and have switched over to 94171715 tonight. My car seems to idle better and is more snappy through transitions. Love it!
There is an error in the 9417 XML, the correct IPW Main Adder is:
Code:
<table name="Injector Cranking Enrichment IPW Adder (Main)" category="Main Map Fuel Settings" address="56AE" type="2D" level="1" scaling="TimeInjCranking"> <table name="Coolant Temperature" address="67bc" type="Y Axis" elements="9" scaling="Temp"/> </table>
#1522
Phenem.....I never noticed that......good catch. I don't think it will make all that much of a difference.....9653 is the same way. I believe it had to do with how the Alt portion was made up. I tried different scalings and different size tables and the values never match exactly.
#1523
#1527
Here is the recompile loaded with the SD tuning tables... I have not verified if this works yet as I have not started tuning the SD yet. But it should work. Just add the XML file to the ecuflash directory and then modify your ROM ID as explained below and the SD tables should pop up with all the MOD 7 stuff.
Fixed and emailed it to ya buddy! If anyone sees any other issues with the XML provided, please let me know! I just used r3compile's XML, added the SD and MAT bits, did the patches, and posted. Tested and verified on a buddy's car we just converted to SD, but I'd like more to test it if possible!
#1529
There is no rom in this attachment, only the SD xml.
Correct, my bad! Fixed shortly on once phenem reposts!
Just the xml for the SD really does no good to anyone. People want pre-patched roms with working xml packaged together. This was the format for option5 for the 96531706 rom and its what I am trying to follow for the 88591715 rom we're posting now. This will be a truely plug-and-play SD rom; awesome but dangerous
