TephraMod V7
#1666
Are you on the JDM Evo IX?
I'm quite sure there are a number of differences between the 88570008 and the 88580014.
That's why I am still waiting for a version of the 88570008. Nonetheless, it would be great if you can let us know what other problems you encountered when running the 88580014.
Or has anyone been running successfully the 88580014 as a replacement for 88570008?
Cheers!
#1667
Hi Mark,
Cheers!
Cheers!
Yes, I am on JDM EVOIX. I am tyring to use 88580714 now and just realised that the engine light will comes on everytime cold starting. Once I clear the codes it will be fine.
Cheers
mark
#1669
94170015 UPDATE
Hi All,
Two problems have been found with the 94170015 ROM
1) gear boost doesn't work, it doesn't calculate the rpm/speed ratio at all
2) boost error/tbec doesn't work, my "stock" rom has bad values for the Wastegate activation/deactivation table
I will be posting up fixes for these problems soon - once they are field tested
Sorry for the inconvenience!
Cheers
D
Hi All,
Cheers
D
#1670
While we are on issues... can someone else verify that the 88591715 rom's launch maps work ? I want to see if it is just my car, but my launch maps act the same as the old 2 step does.
#1673
I want to upgrade to the Tephra v7 mod , I have downloaded the 88590715 for my usdm evo ix , I opened the download and went ahead and added the .xml file to my ecu flash directories , I started setting up the timing /fuel/maps in ecuflash once I was ready to start adjusting the Mivec map I noticed iddle /mivec names are visible to me on ecuflash but the mivec table is not there and yes I have downloaded the correct file. I need help I will sppreciate if someoen can help ?
#1674
download the 88591715, they are for sure in there. Just copy the mivec section into your rom and they will show up. I think i noticed that also and just added them in.
#1676
no, that is the SD rom... I know i put the MIVEC tables in it though. So just copy that section into your 0715 rom and you will be good, or even better, email me and i will send you my converted 0715 xml. jsnrchtr@aol.com
#1680
