TephraMod V7
Old Jul 24, 2010, 10:47 PM
  #1951
teribble's Avatar
Originally Posted by phenem
EvoScan XML Data to add:
Code:
<DataListItem DataLog="Y" Color="" Display="Gear" LogReference="Gear" RequestID="40" Eval="x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="5" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="RPM_SPEED_RATIO_AVERAGE" LogReference="RPM_SPEED_RATIO_AVERAGE" RequestID="42" RequestID2="43" Eval="x/36.37" Unit="rpm/kph" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Airflow Rate gm/s" LogReference="gmas" RequestID="00" RequestID2="01" Eval="x*0.0236" Unit="gm/s" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="4" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load" RequestID="41" Eval="1.3*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="Displays state of the throttle. High voltage or % value means a more open throttle. When logging engine activity (especially on the dyno), it is useful to log throttle position. This makes it easy to see when a power run begins and ends i.e. when the driver's foot is depressing the accelerator fully. Some mitsubishis show up to 20% when your foot is off the accelerator, and will show a max of 90-99% when your foot is fully applied, this is normal.&#xD;&#xA;" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="Airflow 2Byte" LogReference="AirFlow2Byte" RequestID="02" RequestID2="03" Eval="6.29*x/64" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3000" ChartMin="0" ChartMax="2500" ScalingFactor="0.1" Notes="" Priority="4" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Airflow Rate lb/min" LogReference="lbamin" RequestID="00" RequestID2="01" Eval="0.00312*x" Unit="lb/min" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage Gasoline" LogReference="mpg" RequestID="CALC" Eval="5.9*[Speed]*[AFRMAP]/[lbamin]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage E85" LogReference="mpge" RequestID="CALC" Eval="4.18*[Speed]*[AFRMAP]/[lbamin]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />Omni 4-Bar MAP
<DataListItem DataLog="Y" Color="" Display="OMNI MAP" LogReference="OMNIMAP" RequestID="38" Eval="0.2369*x-14.7" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="42" ChartMin="-15" ChartMax="42" ScalingFactor="1" Notes=""/>
Where do i post this in the Data XML? I tried to post it under mode 2 in evoscan v2.5 2and it said something about already having a gear reference.
Old Jul 25, 2010, 02:01 AM
  #1952
AlexEvo6's Avatar
you should delete or modify the initial request.
You can tweak the xml or edit the request in evoscan with ctrl-e
Old Jul 25, 2010, 07:45 AM
  #1953
teribble's Avatar
I found it. It looks like you need to paste it in the data.xml under obdII and it works fine. It was late last night and i wasn't looking to hard!
Old Jul 27, 2010, 07:55 PM
  #1954
evane's Avatar
how do i disable the P0141 test? i am getting this CEL and need to know how to get rid of it! im sick of the SES light =(....i disabled the P0401 code by changing the periphery...
Old Aug 1, 2010, 05:15 PM
  #1955
wizzo 8's Avatar
Subscribed
Old Aug 1, 2010, 07:11 PM
  #1956
drifterific's Avatar
Is there any definitive way of getting the EvoScan Map Tracer feature working with 96530706 v7? I had it working on my stock rom with 2 byte load but after editing the EvoScan Xml with the mods listed on the second post I got 2 errors from
So I pulled them out of the Xml and now EvoScan loads properly but when logging just 1byte load Maptracer shows nothing at all. Any tips?
I do have a omni 4 bar mapsensor and there was nowhere in 96530706 to put the scaling for the map sensor
Old Aug 2, 2010, 12:01 AM
  #1957
STi*guy.kiev's Avatar
Evo 7 jdm/arab
hey can I tune with SD in the 90550001 ROM v5.10?
when will the V7 be working for the 90550001?
Old Aug 6, 2010, 01:20 AM
  #1958
thephra, anything?
Old Aug 6, 2010, 06:41 AM
  #1959
Icem@n's Avatar
Originally Posted by STi*guy.kiev
thephra, anything?
Waiting patiently also too man.
Old Aug 7, 2010, 12:31 AM
  #1960
VGergo's Avatar
Hello
If you diseable the high octane ign maps lookup in the Periphery 0 bit 7 than you have tune the low oct ign map and high oct fuel map and the Ecu can not lowering timing any degrees on knock ? Or is there anyway to turn off the knock sensor in the V7 9653 ?
Old Aug 7, 2010, 11:33 PM
  #1961
Michal_6's Avatar
Hi
Nobe here,
I've got E8 EDM ECU with ROM 97250001, with switched off EGR and Rear O2 sensor, immo off implemented in E6 TME with E8 engine and E6 original haerness via patch harness.
The question is which ROM I can use with this ECU to start with TephraMOD ?
My 97250001 rom was downloaded from Ecuflash page and E5/E6 to E7/E8 ECU swap topics
Michal
Old Aug 8, 2010, 04:02 AM
  #1962
tephra please confirm whether If I can use either 5.10 or V7 to tune my evo 7 rs2 with speed density.
Old Aug 8, 2010, 05:01 PM
  #1963
tephra's Avatar
probably use V7, but use one of the preset SD ROM's...
Old Aug 9, 2010, 06:09 PM
  #1964
ecktt's Avatar
There is a V7 for E7?! Can anyone point me to it?
Old Aug 10, 2010, 01:37 PM
  #1965
burgers22's Avatar
There are a few guys in the UK running SD on the 9055 ROM, so you good to go. Contact cossie1 on here or at www.geekmapped.com
I'm waiting on the 9055 V7 as well, I've gone back to V5.10 as my car ran like a bag of spanners around town on the 96532706 V7, WOT and cruise was fine, but start and idle was nasty.
Quick Reply: TephraMod V7
