TephraMod V7
Old Aug 21, 2010, 09:55 PM
  #1996
Appauldd's Avatar
Yeah, I read that previously, but no conclusion was ever made.
Old Aug 21, 2010, 09:58 PM
  #1997
Appauldd's Avatar
Also, might re-scaling as we do change the point of crossover? Without the exact code and a table to track it, we don't know. There is more than just me out there that has this goofy cut out at low rpm when boost just starts to build.
Old Aug 22, 2010, 08:59 AM
  #1998
wreckleford's Avatar
You could just remove relay 3 and bridge the contacts to engage the high circuit at all times. Do it as a test to see if the switching is the source of your problem.
Old Aug 22, 2010, 01:36 PM
  #1999
Appauldd's Avatar
The bridge was on the "to do list". I was hoping to get the proper table to adjust it all electronically though.
Old Aug 23, 2010, 12:34 AM
  #2000
Mr.Nik's Avatar
I have firmware 94170008, what firmware I use 96530706 or 94170715?
Thank you
Old Aug 23, 2010, 01:10 AM
  #2001
Boosted Tuning's Avatar
Originally Posted by mr.nik
i have firmware 94170008, what firmware i use 96530706 or 94170715?
Thank you
94170715
Old Aug 25, 2010, 12:56 PM
  #2002
Dragracer187's Avatar
Is there a metric version of V7?
Old Aug 25, 2010, 01:05 PM
  #2003
evo_gerard's Avatar
90550001 please would really like big maps!
Old Aug 28, 2010, 03:07 AM
  #2004
VGergo's Avatar
Option 4 96530706 (v7 + Mods) rom the base MAP sensor scaling is for Omni4bar ?
How I checked the xml all of the boost tables scaling useing the Omni4barMap.
Old Aug 28, 2010, 11:46 AM
  #2005
Shy
Shy's Avatar
Smile
Hi guys!,
Thanks Tephra for all your great stuff enhancing the evo community worldwide
I wanted to ask about the NLTS for my evo 9 (Rom 88580015). Is it available? how can i install it? etc
On another note, I heard from everyone its impossible to activate the antilag system on stock ecu.....is that true? anyway around that??
Have a nice day!
Cheers!
Old Aug 29, 2010, 04:23 PM
  #2006
Icem@n's Avatar
X2. Anxiously awaiting also
Old Aug 30, 2010, 01:40 AM
  #2007
project_skyline's Avatar
Hey tephra!
What rom would work for a JDM Evo 7 with current rom 98640014?
Old Aug 30, 2010, 02:41 AM
  #2008
burgers22's Avatar
Originally Posted by project_skyline
Hey tephra!
90550001 is what you are after. I've been running mine on the version 5.10 for sometime, I did get 96530706 to run with no CELs, and though on boost was fine, idle and fuel consumption were always an issue. Tephra did indicate he had a 90550001 V7 nearly finished, but he's a busy guy, so I don't think it's been tested fully yet.
Old Aug 31, 2010, 12:17 AM
  #2009
Thanks for giving me that update.
Tephra if you need a tester I got someone who can do some testing for that rom.
Old Aug 31, 2010, 01:47 PM
  #2010
mountainturbo's Avatar
Originally Posted by Monochrome
Might I suggest adding the rear O2 sensor heater disable to this patch as well?
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c62a" type="1D" scaling="Hex16"/>
Open up the ROM, navigate to the "Mods" section, change "Rear O2 Heater Patch" from "4A0B" to "0009"
My rear O2 has been replaced with the wideband.
This might also work but I need to confirm the address!
Code:
	<table name="Heater CEL" category="Rear O2" address="2c61e" type="2D" level="2" scaling="blobbits">
		<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>Rear O2 Heater CEL Enable</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
		</table>
	</table>
Does anyone know if this code works with Option 4 96530706 (v7 + Mods) ? I replaced my stock 05 rom, and although I disabled the rear 02 sensor (I have a wideband installed) I get a p0125 error, and I think it's from the rear heater circuit not functioning. I believe this code will fix it, but I don't know if it will work with that rom.
:edit:
Nevermind, I'm an idiot, this code is already in the rom. Sooo... anyone know why I would keep getting a P0125 CEL with the new rom? :help:
Quick Reply: TephraMod V7
