TephraMod V7
#196
Registered User
#199
Yeah, we're all on the same page about that now. The problem is with the scalings for the BLEL and BEC when used with PSI based boost control. They need to be scaled for whichever map sensor being used so the numbers in the tables match the actual PSI levels read by the map sensor. All we need to do is have those tables reference the MAP sensor signal rather than LOAD.
#201
I dont want to rush in any way, but is there an ETA on the excel sheet to convert to the big map or did I miss it? Donation sent.
And for crying out loud people, take the time to READ THE ENTIRE FIRST 2 POSTS. Half the posts are "awaiting" a rom that is not coming. They're universal for USDM cars.
#204
OK, I have DMA/livemapping ported over to the V7 final - bigmap for 96530706. I just need some time to test it out and if everything is working OK, I will post up the instructions.
I don't think too many people use DMA/livemapping, but hopefully I can test before the weekend is here.
Eric
Eric
#207
If you are interested in setting you car up like mine in my video, here is the post I made about what I have in order to get this result:
https://www.evolutionm.net/forums/7171893-post961.html
Or is neccesary one patch in ecuflash with one instruccion(offset, etc)?
Other question... Km/h = 8 and % to 95, and stationary rev limit to 5000? or 7600?
Thanks Phemen!
#209
I see this post. Ok, all -20º and 10.5AFR, but my rom v5 limited to -10º (log with evoscan), with v7 is possible retard ign to -20º?
Thanks Phemen!
Thanks Phemen!
I would say to set your stationary rev limit to whatever your car launches good at. The way to find out is to do some launch tests and see if it bogs or not.
