TephraMod V7 - Page 234 - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
EcuFlash
TephraMod V7
Old Aug 19, 2018, 05:47 PM
  #3496
Is this still constant with sending out the roms after receiving a dontation? Or will it take a while to receive? Or if anyone has a copy of the 90550001 V7 that they are able to send me that would be awesome, I have already donated to him by after reading a few posts from the last past year, some people a are saying that he is inactive or takes a few months to send it out 😃
robwvii is offline
Old Sep 13, 2018, 03:51 AM
  #3497
Missing some tables in V7 for rom 0715.
Boost desired engine (Psi)
Boost Adder (psi)/(load)
boost error correction (PSI/LOAD)
Any reason why they are not included, or am i experiencing some error? I'm pretty sure there is more tables missing as well, but for now just concentrating on ECU based boost control.
OHM_Racer is offline
Old Oct 1, 2018, 05:04 PM
  #3498
Hello ,
I would like you to help me with something, I've been searching for 88580014 rom without success. Can someone send it to me please XML and ROM or tell me where to get it?
I would be very thankful for this.
thanks,
best regards,
LONZO is offline
Old Oct 3, 2018, 06:27 AM
  #3499
Gavin Spratling's Avatar
Gavin Spratling is offline
Old Oct 15, 2018, 06:31 PM
  #3500
downloading
hello,
i have a 97 Mitsubishi eclipse with a 04 evo8 ecu in it i was wondering what package i would need to download to tune this ecu i am new to this and im not 100% sure which one to download....
also im not sure what the rom and definition is.
Last edited by tiller77; Oct 15, 2018 at 06:32 PM. Reason: forgot to add something
tiller77 is offline
Old Oct 22, 2018, 10:13 AM
  #3501
Thanks! Works flawlessly
best regards,
LONZO is offline
Old Nov 22, 2018, 08:43 PM
  #3502
Unknown rom image Help .
Hello bought the car with cold start issue try to fix my self read ecu with ecuflah its unknown rom id 88596715 add every single xml file to evo folder but no luck. i will apricitae if any body got xml file for my rom i will appreciate and donate if have to thanks. And what need to change in rom setting for cold start fix. Thanks someone please help .
File Type: bin
toorboy is offline
Old Nov 26, 2018, 01:10 PM
  #3503
Imobilizer hex 2006 MR
Hello
Sorry for the noob questions but i just flashed over v7 from stock and i have immobilizer code but i cant find the hex. The v7 shows the hex option but the stock only shows imobilizer code and now the car wont start. Im going to be daily driving the evo so i dont really want to disable the immobilizer. Im sure its something simple that y'all can help me with haha im a noob at this stuff.
Thanks!
hopsteadymusic is offline
Old Nov 30, 2018, 07:58 PM
  #3504
any one got 88596715 xml file thanks.
toorboy is offline
Old Dec 10, 2018, 03:47 AM
  #3505
Hi guys,
I just wanted to find out if either of these will work on a 2001 Evo VIITIA.
TookieZA is offline
Old Dec 10, 2018, 08:43 AM
  #3506
mines5's Avatar
Originally Posted by TookieZA View Post
Hi guys,
9417 and 9653 will work.
mines5 is offline
Old Dec 10, 2018, 08:03 PM
  #3507
awesome thabk you very much
TookieZA is offline
Old Dec 27, 2018, 01:57 PM
  #3508
Newb to TephraMod V7 here. Just as I got familiar with the standard software, I decided to try the mod. Now I have some stupid questions.
88590715 Rom USDM Evo 9
- Once TM was installed and working, I cant access my old fuel and timing maps. I have to remove the TM to view my old maps. The new maps are all at a fixed value when viewing them with the TM. Is this normal or should there still be somewhere that I can see my old maps?
- Are fuel and timing the only things I need to add back in since they are now on the Big Maps? And yes I know about the Big Map Translator.
- Should everything else on my current tune be the same on the TM? Meaning once I add in my fuel and timing maps, things like the 4 bar map and injector scaling will still be the same and I wont have to mess with them?
- As far as MAP switching goes, are there 3 maps plus a valet? I believe I saw, base fuel, alt fuel, alt fuel123 and valet mode.
More questions to come after I start messing with it some more.
Lumpy Sticks is offline
Old Jan 3, 2019, 12:21 PM
  #3509
No one tuning their own car anymore? I think I am just going to load in the calibration I made and see what happens.... Easy enough to put the old cal back in if it doesnt work I guess.
Old Jan 3, 2019, 02:02 PM
  #3510
Biggiesacks's Avatar
If you want to see your old rom values just open both roms at the same time in ecuflash. You should spot check both roms for discrepancies. If there are any research why. If you aren't on stock injectors then you will definitely need to copy over your injector calibrations, same for maf settings if you have an intake and it was tuned. There is a valet mode, no maps for it that i know of. Then there are 3 other sets of maps, 2 you can switch between for regular use and launch maps.
Biggiesacks is offline
Quick Reply: TephraMod V7
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
