TephraMod V7
#623
Registered User
nope 3 port, but just so i dont ask again what do i do for either:
1. the stock solenoids?
2. removed solenoids with a 3 port
3. removed solenoids with an external BC (manual or electronic)
i was gonna say i got to disable the CEL for the solenoid for the stock BCSs, but JDMs dont throw that code. i am such a noob
#629
The below maps where mentioned in the Poor Cold Idle thread :
https://www.evolutionm.net/forums/ec...ml#post7637804
Code:
<table name="Ignition Unknown Map (warm-up?)" category="Timing" address="61c9" type="3D" swapxy="true" scaling="Timing"> <table name="Load" address="6910" type="X Axis" elements="19" scaling="Load"/> <table name ="RPM" address="68de" type="Y Axis" elements="20" scaling="RPM"/> </table> <table name="Ignition Unknown Control (warm-up?)" category="Timing" address="61b6" type="2D" level="2" scaling="uint8"> <table name="Engine Temp" address="6a36" type="X Axis" elements="8" scaling="Temp"/> </table>
#630
Would anyone be able to convert my pre-V.7 map to V.7 (or if anyone knows if any tuners are offering this service). I am current running V.5 with Alt Maps (E-85 & 91 oct + meth) and load-based boost control (88590015 ROM on EVO IX MR). I have maps and xml files. I will be more than glad to compensate you for your time.
I'd like to switch to gear PSI-based boost (already running GM boost solenoid and JDM MAP sensor) and disable EGR.
In mid-Nov, after SEMA, installing hardware for SD and closed loop cruise AFR control via AEM wideband as well as upgrading from a FP Green to Red, MAP O2 dump, MAP Rev 2 intake manifold, Buscher double pumper. Parts are ready, but just waiting until SEMA is over to have Harman Motive in Torrance, CA perform the installs. Then planning to have RRE here in SoCal do the tuning for the post-installation.
Thanks,
Jay
MrFred and Evo_Kid... Thank you so much for the offers to help me make the conversion to V7... PM/e-mail sent. Let me know if you're going to SEMA. I owe you both a beverage of your choice.
Thanks,
Jay
