new live map app
#466
I have a question. In the PDF instructions it says to make sure you are using alternative maps. What exactly is this referring to? Does it mean using a modded rom like tephra or does it mean using the alt maps in tephra or something completely different? Sorry for my ignorance if its something obvious that I'm overlooking. Most of the time I have tried to tinker with my car its while trying to watch a 2yo and a 5yo playing in the yard lol.
#467
#471
ziad I turned on the "enable SD" but then when I click on the start logging I get an error that say Exception index not greater than zero.... (i tried on my way to work) so didn't look over it too much do I need to set a map index some where? I'll look more myself on the way back home but thought I'd ask for an easy answer
cheers
Andy
cheers
Andy
#472
ELM and Evoscan are reporting 22.3 AFR with the engine not running but ignition on. Logworks shows a 20.8 which would be the correct value. Any ideas? Scaling correction maybe?
#474
Yep, that sounds right, donner said the same and my test with the engine running showed the AFR on the LC1 the same as ELM with the original scaling. I wanted to be sure as I'm trying to tune 3D SD and dailing in the AFR on my own is not that easy, especially at part throttle off boost. I'm running full time open loop to get the VE correct.
