New thread for Speed Density tuning?...
Old Mar 1, 2010, 04:43 PM
  #421
bigric09's Avatar
judging by that, id say you need to get off of the 1:1 like i had to. What are your fuel trims looking like ?
Old Mar 1, 2010, 08:11 PM
  #422
qnz
qnz's Avatar
hmm ya, I see the steps l2r99gst posted to dial in your map. I will try that with my latest log.
Old Mar 2, 2010, 03:59 AM
  #423
bigric09's Avatar
it will be a little hard that way as you wont have the spreadsheet needed for logworks. I am trying to make a spreadsheet now that doesnt need logworks. Its a pain, but should be helpful for everyone.
Old Mar 2, 2010, 06:33 AM
  #424
travman's Avatar
Originally Posted by qnz
read thru this thread about 4 times. I learn something new everytime I read this.
Im confused by the RPM VE table. People have said that by lowering the RPM VE will make the car leaner, and vice versa. Here is my current VE tables (just the default rom values)
with these values, the car idles at 13afr. This is on a fully warm car in open loop only. I change the RPM VE to 70 in the first 4 rows and the car still idles in 13 afr. I drop it down to 40 and it is still the same. I can bump my fuel map like 4 points leaner and the car will idle at 14.7 but we dont want to do that right? I can change the injector size to 532 and it will idle at ~14.7 but I shouldnt have to do this on the 560 injectors? Upping the injector size works for me, but how else are you guys making the car leaner/richer using just those 2 tables?
lower the load% some on the kpa/load table in the lower kpa area where your idle and normal driving duties are done.
Old Mar 3, 2010, 10:59 AM
  #425
qnz
qnz's Avatar
I just followed l2r99gst's steps in post #400.
Thanks. that helped a lot in understanding tuning for SD. You're right, changing one of the 2d tables might fix one cell, but has the rest of the row out of wack.
Old Mar 4, 2010, 01:00 PM
  #426
qnz
qnz's Avatar
Wouldnt it be better to lock in one of the 2d tables so that you dont have to mess around with two tables and a fuel map to get the tune right?
I was looking at Bigric's log and l2r's suggestion for bigric's Map VE. I noticed that when I set the rpm on the Y axis and kpa on the x axis and populated the graph with 1byte load averages, the results were very very close to what l2r suggested, but in less words.
Since the map VE table needs kpa (known constant) and load (known average), wouldnt this be easier to lock in this 1 table, and then only adjust the RPM VE and fuel map for the tuning?
Attached Thumbnails New thread for Speed Density tuning?...-capture3.jpg   New thread for Speed Density tuning?...-capture4.jpg
Old Mar 4, 2010, 01:42 PM
  #427
hammilljr's Avatar
Very detailed, I'm gonna read all 29 Pages!
Old Mar 4, 2010, 02:42 PM
  #428
bigric09's Avatar
i just got done adjusting my buddies car and essentially thats what i did. Did the log, noted the adjustments that needed to be made via the mapve table, adjusted those and then made the changes in the rpm table as well, and she was right on.... and then its fuel map time
Old Mar 4, 2010, 05:45 PM
  #429
Slo_crx1's Avatar
I will reiterate for clarity's sake since it's been said numerous times through this thread...
99% of the time your load% and kPa will NOT match as a 1:1 ratio when you're under the 100% load/100kPa range. They will need to be set according to your logs to achieve the desired result and will affect your idle and closed loop afr's.
Old Mar 4, 2010, 05:56 PM
  #430
bigric09's Avatar
very good point...
Old Apr 1, 2010, 03:01 AM
  #431
Slo_crx1's Avatar
Just as an update, I finally got my large Holset turbo on the car this past weekend and tweaked the SD rom. The RPM ve tables make life so much easier, and even after spending a few minutes dialing in my 1000cc injectors I was able to have my feedbacks within a +/-5% range in 20 minutes. Amazingly enough, I only had to take out a hair of fuel in the top end of the rpm range, and I noticed the strange "lean warm-up" period is gone, as it now sits around 13.5-14afr during warm-up at all times with absolutely no break up through the rpm. This patch works EXCEPTIONALLY well with large turbos, and I highly suggest anyone with a large turbo give it a shot, your car will love you!
Old Jun 8, 2010, 02:52 AM
  #432
VGergo's Avatar
Hello is it hard to scale the VE table ? Or some one coud post me one for an Evo 8 engine with 9 turbo and hks 264cam ? :$ :$
Old Jun 18, 2010, 08:49 PM
  #433
BoostFTW05's Avatar
subscribed, going SD next week!!!
Old Jan 9, 2015, 09:24 AM
  #434
mavraolan's Avatar
Did you know that JDM evo IX came with MAP and IAT?
Guys I am actually trying to get some information-help about speed density conversion on my jdm evo 9.
As you can see in the picture below my car came with a map sensor (3bar) and an IAT from the factory. What I want to know is, if I wanted to go on SD route could it be possible to tune the car as it is?
I also bought an Omnipower 4bar sensor, can the omnipower be tune with my stock IAT for SD?
Old Jan 10, 2015, 10:27 AM
  #435
todd6027's Avatar
you can use either map sensor and your stock iat sensor
Quick Reply: New thread for Speed Density tuning?...
