Official / Injector Scaling and Latency Forum
Old Jan 31, 2010, 12:18 PM
  #46
SoCalRedLine's Avatar
Originally Posted by Brad74
For PTE 1000 cc, pump gas, I'm using :
Injector scaling : 886
Latencies :
3.720
2.088
1.440
1.080
0.840
0.672
0.552
Hope that will help you.
found this on page 58 of that thread. it seems to be a more correct PTE 1000 scaling
Old Feb 1, 2010, 09:58 AM
  #47
blkVII's Avatar
Will scaling/latencies be different for fuel over in Australia? I'm not sure what US pump is equal to over here...?? Anyones help would be great!
Cheers.
Old Feb 1, 2010, 12:48 PM
  #48
project_skyline's Avatar
Scaling will vary with different fuels. But if your stuff is the equivalent of what is over here aka 91-93 octane you shouldn't have to mess with it much if at all.
Old Feb 2, 2010, 01:36 PM
  #49
tvor's Avatar
Clarification point here? If you have one of the sets of injectors with scalings listed in this thread, would it be safe to say that you would be able to take those values, plug them in, and be done with it?
The reason I ask is because I would prefer to install my injectors at home and then drive up to Chicago for a tune, without having to pay anyone to install them there for me, or try to do it in the AMS parking lot, lol. Obviously I would just be idling and cruising with minimal acceleration on the trip there. I don't have a WBO2 at my disposal so I am a bit leery of having to adjust anything on my own, unless that is unnecessary.
P.S. - this will be PTE 1200's on 93 octane.
Old Feb 2, 2010, 02:00 PM
  #50
donour's Avatar
Depending on how good the numbers are, yes. Once you have scalings and latencies that start well and result in decent fuel trims you can drive around in closed loop. Remember, closed loops targets 14.7:1 mixtures which the narrowband o2 sensor does measure accurately. That's the point after all...
d
Old Feb 2, 2010, 02:31 PM
  #51
bigric09's Avatar
anybody with FIC 1650 non bluemax ? Or a good ball park to start in. I can make a good guesstimate, but I'm hoping somebody has some help. Thanks
Old Feb 2, 2010, 04:08 PM
  #52
lan_evo_mr9's Avatar
aren't you supposed to use the easytune for those?
Old Feb 2, 2010, 04:09 PM
  #53
bigric09's Avatar
i have no idea, i havent scaled anything bigger than 1200s. Do you have a link or anything i can follow ?
Old Feb 2, 2010, 04:48 PM
  #54
I'm almost positive that you are supposed to use the "EasyTune" in conjunction with their larger injectors....its say on their site. Google FIC or something like that.
http://www.fuelinjectorclinic.com/cg...key=IS226-1650
Old Feb 2, 2010, 08:48 PM
  #55
bigric09's Avatar
everything i have read has shown bad experiences using those. Id think that with all of the knowledge we have here like JB and pals, we should be able to handle it. I havent given them a go yet.... im sure ill get to what i need to do. Just looking for a ballpark starting point
Old Feb 2, 2010, 10:09 PM
  #56
There are a lot of scalings on here, not all are going to work right off the bat. You might find some that will work and your done with it but always double check.
I posted in a thread made yesterday with some PTE 1200 pump gas scalings, if you need them check it out.
You dont have to, its not required. It just helps with driveability on some of the larger injectors.
Old Feb 3, 2010, 12:23 PM
  #57
tvor's Avatar
If I used the scalings provided and then checked the fuel trims to see how close it was would that be a fairly accurate way of telling how on or off they are, or is it necessary to use a WBO2 for that?
Old Feb 3, 2010, 02:58 PM
  #58
You can just log 02 trims. WB02 would be needed for fuel map tuning though.
Old Feb 3, 2010, 03:24 PM
  #59
merlin.oz's Avatar
blkVII, which injectors do you wish to use, and presumably on a 9?
Old Feb 3, 2010, 07:40 PM
  #60
W2J
W2J's Avatar
still looking for some denso 720's that works
Quick Reply: Official / Injector Scaling and Latency Forum
