HOW-To 96260009 JDM8MR to 96530706
Old Dec 14, 2009, 03:42 AM
Registered User
rolly1818's Avatar
looks good, i did a similar rom change for friend a couple months back using the same roms, car started and idle-d fine with no CELs.
all i did was the Bits, Injectors and Immob code Removal. Ziad if you have time can you take a look?
Thanks,
Ravaal
Old Dec 14, 2009, 04:19 AM
leecavturbo's Avatar
what are the benefits of this rom over the jdm's ziad breifly?
Old Dec 14, 2009, 05:16 AM
Registered User
rolly1818's Avatar
this should work the exact same ziad's rom, i dont see any difference, i would just like to post it for everyone.
Old Dec 14, 2009, 05:21 AM
Registered User
rolly1818's Avatar
Thanks,
Ravaal
Old Dec 14, 2009, 07:49 AM
Stradale's Avatar
Rolly1818 did this rom change for me too (From 96260007) and after I uploaded it, the engine start at first crank and no CEL code came up. I rev it a few time and everything seems normal. After I learn about how to tune with this new upgrade I will drive the car.
Thanks You Very Much Rolly/Ravaal!!!
Old Dec 14, 2009, 07:52 AM
Registered User
rolly1818's Avatar
no probs, i just wanted ziad to look over the rom i sent you to see if i missed anything.
Old Dec 14, 2009, 11:42 PM
ziad's Avatar
i didnt get a rom rolly? did u email or pm.... any way the reason for this thread.
i wanted to use V7 tephra
i wanted to use Livemap.
both currently not available on 9626000x roms. i have tried to put all steps to ensure the rom works fine. if u do not change the injectors ur trims will be out. if u change the injectors but not the latencies then ur trims will be out again... if u change both but not the maf compensation table then u will be running 1AFR leaner 4000+ rpm.
Old Dec 15, 2009, 02:02 AM
ziad's Avatar
ahh yeah and have lift off pops if the values in decel table are not changed. obviously i didnt go step by step changing one thing at a time. i did most of them ran the car it was good... but then a few more tweeks were needed like the fuel issue from MAF Compensation
Old Dec 15, 2009, 05:51 AM
Registered User
rolly1818's Avatar
can you PM me your emil addy?
i am gonna try this on an evo 7...
Old Dec 15, 2009, 07:14 AM
good work ziad. live mapping working perfect?
Old Dec 15, 2009, 03:53 PM
ziad's Avatar
yeah the current build is quite stable and have been using it for a few weeks now. the only thing i noticed was that i wish i could change multiple values quickly like in ecuflash by pressing + or - or = and updating a selection of cells...... something i will work on soon anyway
plus the eeepc i have does not refresh its screen fast enough so map tracer is useless
Old Dec 16, 2009, 02:05 AM
veszett's Avatar
fluctuating boost
im quite new to ecuflash and i hope im posting this in the right section! i dont know if anyone is having the same problem as i am but i thought i'd put it out there maybe you guy's know whats going on with this rom on my evo. i'm having trouble with boost and i find from about 3500rpm up my boost is fluctuating as i accelerate. i logged it and evoscan shows my load rising and then dropping, wgdc also going from like 90 to 0 suddenly then back up etc. i dont know whats going on i feel like im riding a rubber band, lol!! all the settings that i could change over from 9725001 are the same and even tephra 96260009 works fine. i installed my 3port (tactrix) in interrupt mode and its plugged into the grey connector (other solenoid plug isn't connected) but it did the same thing when i had both 2 ports connected. i dont know whats going on, can someone give me some advise pls, id really appreciate it!!
Old Dec 18, 2009, 04:17 AM
daymean's Avatar
Check you boost error corrections and see how large error corrections u have..
Does your wgdc have smooth transitions?
Old Dec 18, 2009, 04:21 AM
daymean's Avatar
Originally Posted by veszett
hey daymean, did you manage to find out/fix the rich idle?? im having same problems. i have a bit of a spray going on at the exhaust where i start the car up on the driveway
I am having a similar problem ....will let you know when/if i make any headway
Old Dec 18, 2009, 11:23 AM
veszett's Avatar
boost corrections i copied over from 97250001
27.5
27.5
22.5
18
14
10
-5
-7
-8.5
-10
-10
-10
-10
i think i'll zero them out tomorrow if i get time and see if that makes a difference. it would be strange if that was causing the problem because that and my wgdc is the same as my current rom. when i log wgdc corrections in evoscan it logs as 63.5 and its constant so i think there's something amiss there with logging settings, maybe something isn't defined correctly?
in 96260009 i have:
5.5
3.5
1.5
0.5
-2
-4
-6
-8
-11
-11
-11
but again both those roms work perfectly, without problems...
my wgdc settings are:
100
100
100
100
100
100
90
74
63
60
61
63
72
88
100
100
that what you mean when u say smooth??
Quick Reply: HOW-To 96260009 JDM8MR to 96530706
