EcuFlash
IPW minimum?
Old Jan 18, 2010, 05:23 PM
My dsm with 550cc/min idles fine, it is the log above. The car I worked on saturday has 2200cc/min and idles at 10:1 and the same 1.28 ms and won't lean out or go to the next lowest ipw on evoscan MUT29.
0xDEAD is offline
Old Jan 18, 2010, 05:40 PM
Here is the same idle log showing STFT. This car on 550's and the other evo with 2200cc/min are logging 1.28 ms at idle, doesn't seem right to me.
0xDEAD is offline
Old Jan 18, 2010, 07:23 PM
phenem's Avatar
Originally Posted by 03whitegsr View Post
Are you finding the RPM and MAP VE table you are using provided good off-idle driveability and AFRs but then idle is extremely rich?
The car has great off-idle driveability and AFR's but the rich at idle....I am going to try and take the RPM vs. VE to 50% and see what happens....
phenem is offline
Old Jan 18, 2010, 08:23 PM
JohnBradley's Avatar
Try adjusting you MAPVE at 39.9 and 59.9, the right hand column is why its rich, values exceed the left.
JohnBradley is offline
Old Aug 10, 2010, 08:36 AM
Anyone ever find a fix for this or a way around it? I have run into the 1.28ms min pulse width on Evo 8s, 9s, and Xs with the 2150s and ID2000s. They all want to idle at around 11.2 A/F and the datalogged IPW in Evoscan bottoms out at 1.28ms and won't go any lower no matter what I try. The cars do idle and run fine, just too rich at idle.
DB Performance is offline
Old Sep 1, 2011, 07:30 PM
benderrodriguez's Avatar
Anyone have good luck with this code
https://www.evolutionm.net/forums/ec...nimum-ipw.html
And 2150's?
benderrodriguez is offline
Old Sep 6, 2015, 12:22 PM
Brandon Robblee's Avatar
Originally Posted by phenem View Post
Here is what we have for SD settings, no matter what we do or change the car wants to idle at 10.9/11!!! Can't figure this out.....
Did you ever get this figured out? I know this was a few years ago, but i am having THE EXACT SAME ISSUE... Driving me insane....
Brandon Robblee is offline
tephra
45
May 26, 2018 04:44 AM
newbevouser
EcuFlash
16
Dec 30, 2016 08:38 AM
Dynotech Tuning
EcuFlash
80
Sep 20, 2016 01:30 PM
tephra
EcuFlash
218
May 23, 2016 04:00 PM
GP148
Ecuflash
Feb 11, 2016 02:59 PM
Quick Reply: IPW minimum?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
