Copy mut table when doing V7?
You would risk losing these MUT requests. I would use exisitng MUT table in V7 and copy over your specific ones if neccessary.
Preconfigured MUT Requests
MUT00+MUT01 = 2byte airflow (ie MrFreds mod in g/s or lb/min)
MUT02+MUT03 = 2byte airflow (ie MAFHz)
MUT40 = 1byte gear
MUT41 = 1byte load
MUT42+MUT43 = 2byte SPEED/RPM ratio (to get your gear ratios correct - if you need to)
2byte load AND 2byte RPM are no longer included and IMHO not needed!
MUT40 = 1byte gear
MUT41 = 1byte load
I'm absolutely lost.. here is what I'm looking at. Can anyone give me some examples of what I should be doing here. Top one is the V7 mut, bottom is my roms mut.
Tried to search for info but obviously I didn't find any answers I was looking for.
Is the mut tabel only for logging purposes?
Here is the same table just without the colors on screen.
