94170715 V7 Issues
Old May 2, 2010, 04:32 PM
  #241
AutoXer's Avatar
Originally Posted by chmodlf
Can someone confirm that uses ECU boost that their Boost error and WCDC Correction is working. Mine always registers -3.087 for Boost error and 0 for WGDC Correction.
I was logging today and the WGDC did not correct downward when it should have.
All my settings appear to be correct. Wow another problem...
Boost error is working for me. However, I'm still tuning the WGDC curve. So, I haven't gotten to tuning the closed loop control yet.
Care to send me your ROM? robbie (dot[ nelson at gmail (dot) com
Old May 2, 2010, 05:22 PM
  #242
chmodlf's Avatar
Originally Posted by tephra
well the boost error has already been covered in this thread... either your not going into open loop or your rpm activation/deactivation is wrong...
sorry about 8425, all the maps are located at 0x3xxxx - so it wont tell you what map your on...
try 0x8426...
does logging gears work? i take it you applied the gear fix?
Sorry forgot to change the scaling for the boost adder. Changed it from 8 to 16 bit and I am sure that will work. Should have searched the thread...
I'll change the addy for the alt maps tomorrow and report back.
Gear is working beautifully.
Old May 3, 2010, 08:16 AM
  #243
mfr122887's Avatar
try 0x8426...
Logging gears is working perfectly.
I tried logging 0x8426 and I am getting 139 on alt maps and 151 on regular. The value only seems to change when the maps are changed. Does this seem right to you? The only reason I ask is because it used to be 0 and 3 and now its 139 and 151.
Old May 3, 2010, 04:07 PM
  #244
tephra's Avatar
yeah 0x8424 (4bytes) is a pointer to the current fuel or timing map (i can't remember which)
so 0x8424 is always 0
0x8425 is 0x3 (because all the maps are at 0x3xxxx
0x8426 is 139 or 151
0x8427 will be different as well...
Old May 3, 2010, 04:12 PM
  #245
mfr122887's Avatar
So using 8426 is the correct way of determining the current map, 139 for alt or 151 for regular?
Old May 3, 2010, 04:17 PM
  #246
tephra's Avatar
yep, well it's one way
and there will be a different number for launch maps as well...
Old May 4, 2010, 09:21 AM
  #247
tnt1106's Avatar
CRAPPPP
found the problem...
edit - can you add this to your tephramod_94170715.xml
Code:
<table name="94170715 GEAR Fix1" category="TephraMod-V7" address="3f16e" type="1D" scaling="Hex16"/>
then change 0x6a2c to 0x8a2c
then flash and report back
does this also apply to the 88590015 roms? I have same issue. thanks!
Old May 4, 2010, 04:02 PM
  #248
tephra's Avatar
no... i will check the ROM code by 88590715 should be ok in this regard...
Old May 16, 2010, 05:18 PM
  #249
chrisw's Avatar
So I hate to bump this thread,
but...
I seem to have problems with the latest patch.
When I converted over to V7 I took my base map from my old tune and moved it over to all the available maps so I could get a base line on the V7 performance before attempting any alternate maps or launch maps. As a result I didn't see this problem right away.
I am bouncing between my main and alternate maps. With V5 I could use my ISC switch to switch between the base and alternate maps, but now the map bounces between different maps before stabalizing
I have attached a log file that demonstrates the problem. For now I am only using one map, basically copying over all my changes to the other maps so I continue evaluating V7.
Old May 16, 2010, 05:28 PM
  #250
tephra's Avatar
what memory address are you logging for "AltMapActive"?
Old May 16, 2010, 07:12 PM
  #251
chrisw's Avatar
requestID 00 according to Evoscan. I used what ever the values were set to with the latest V7 94170715 version with the latest gear patch. The patch was configured on a fresh install of EcuFlash to make sure I didn't create any conflicts.
Old May 16, 2010, 07:14 PM
  #252
tephra's Avatar
well MUT00+MUT01 is setup for 2byte airflow from memory..
MUT00 is NOT setup for what map is currently active..
which is why your getting funny numbers
you can reconfigure a spare MUT to log 0x8426, and that should only cycle between 2 numbers (or 3 if you have launch maps setup)
Old May 16, 2010, 07:24 PM
  #253
chrisw's Avatar
I do not know what those MUT address have been programmed for.
I just used what ever definitions provided in the download. I never touched the mut table.
Old May 30, 2010, 06:11 AM
  #254
VGergo's Avatar
Hello
what coud cause my problem seems like rev limiter @6000rpm ?! But in the limits section the stationary rev limiter and the rev limiter set to 7500rpm ?!
I have omni 4 bar map but If set my Boost desired engine PSI nothing is happend only if I using the Boost desired engine load
In the main map boost control setting the Boost adder ( load and psi ) will add the boost to alt map boost settings to ?
Old May 30, 2010, 09:54 AM
  #255
chmodlf's Avatar
You might check to see that you are not hitting a load that would trigger your fuel cut. Check your settings in the global fuel settings.
Quick Reply: 94170715 V7 Issues
