Break-thru: Reading ACD ECU with EcuFlash
#546
does anyone have a copy of the ralliart T1 map? i have started to gather everything to start tuning acd and would like a copy of this to compare it... also i had a copy of the definitions and my computer seems to have swalllowed them... i know i have opened a few evo 8 maps and now i can't open anything at all... can someone assist me with those i can't seem to find them anymore...
#550
http://www.hamotorsports.com/ecu-plugs-pins.html
you need 1 of each set of pins... and both A and D ecu plugs... that will get you hooked up and then i used a cheap 12v cigarette lighter plug to get voltage...
so can someone help me track down the t1 map? lol
#551
Guys, you do not need ti build a new harness to reflah acd ecu, you only need to put the single wire in pin 25, than connect o.p. in stock obd socket and the reflesh connector to the 'new' wire.
look this thread: page 2 #16
https://www.evolutionm.net/forums/ec...789-acd-2.html
#552
#553
#554
